Plastic battens/strapping
AnthonyPannolino | Posted in General Discussion on May 28, 2009 10:53am
I’m currently building a cottage with 7/8″ corrugated metal siding on the exterior.  I want to leave an air space behind the metal siding but I do not want to use traditional wood strapping/battens.  Does anyone know for a plastic substitute that will not rot over time?
  1. TomE | May 28, 2009 11:01pm | #1
    If you intend to attach the siding with screws you might consider steel furring.
    Azek and similar products are expensive but someone might be aware of a "recycled plastic" product that may suit your needs.
    Sphere | May 28, 2009 11:39pm | #2
    Lowes has a Trex like band board, 10" wide by approx 5/8th thick, you could rip lath outta that.
    "If Brains was lard, you couldn't grease much of a pan"
    Jed Clampitt
  3. Piffin | May 29, 2009 12:34am | #3
    buildings that I have seen similar to that for storage, sheds, barns etc were as follows;
    vertical studs
    Horizontal 2x4 strapping
    The steel siding
    If this is what you have in mind, plastic strapping would not work, because it does not have the necessary structural stability, and if it is any larger than a chicken coop, it would suffer from thermal expansion, either tilting the ends of the building out on hot days, or causing ripples in the surface.
  4. Hackinatit | May 29, 2009 03:03am | #4
    Why not just use layered 30# felt?
    A La Carte Government funding... the real democracy.
