Plastic shims for replacement windows?
Toolpig | Posted in General Discussion on January 20, 2008 04:07am
I’m installing some Harvey “majesty” replacement windows. I’m using tapered wood shims under the screws, which sucks because you never get good backing when driving the screws home and end up bowing the jambs.
The Andersen replacement units come packaged with those plastic u-shaped shims. They look great because they’re flat and you can “stack” them.
Anybody use these? Where can I get some?
TP
  1. DanH | Jan 20, 2008 04:13am | #1
    I bought a pack of plastic shims at HD awhile back -- conventional shape. Used a couple -- they're a little easier to handle than wood.
  2. rlrefalo | Jan 20, 2008 04:15am | #2
     I know the u shaped shims as glaziers shims . Do a search for Glaziers supplies. They are used by  the shower door guys, storefront installers,etc.   Edit: try wgsonline.com
    Edited 1/19/2008 8:21 pm ET by rlrefalo
  3. elicon | Jan 20, 2008 06:27am | #3
    Toolpig:
    Here is a link to some I've bought:
    http://www.glazelockshims.com/products.htm#stackables
    Edited 1/19/2008 10:37 pm ET by elicon
    1. Toolpig | Jan 20, 2008 03:11pm | #4
      I saw those. Did you buy them online or at a lumberyard?TPToolpig (a.k.a. The man formerly known as "Toolfreak" and "Toolfanatic")
      1. elicon | Jan 20, 2008 10:12pm | #12
        I bought them online about a year ago.
    2. Jim_Allen | Jan 20, 2008 03:20pm | #5
      That looks like a great system for shimming. They mentioned 1/16" and 1008 pieces for about $52. That works out to $.82 per inch. Am I reading that right? Bob's next test date: 12/10/07
      1. calvin | Jan 20, 2008 03:32pm | #6
        Got a pile from some ironworkers.  They are some kind of handy.A Great Place for Information, Comraderie, and a Sucker Punch.
        http://www.quittintime.com/
        1. MattSwanger | Jan 20, 2008 03:35pm | #7
          Our granite fabricator uses them when shimming his tops.  I hadn't seen them until 3 weeks ago and I like the idea. Woods favorite carpenter
          1. calvin | Jan 20, 2008 04:50pm | #9
            The beauty is the thick (thin) ness of them.  And the anti-crushability.A Great Place for Information, Comraderie, and a Sucker Punch.
          2. MattSwanger | Jan 20, 2008 04:58pm | #10
            Thats why the granite guys use them,  they told me that the tops won't crush these like cedar shims.
            basswood | Jan 20, 2008 10:44pm | #14
            Matt,I use the plastic composite shims when installing base cabinets for the same reason the granite guys use compression resistant shims...it doesn't matter what kind of shims they use if the cabs are set on cedar shims--the weight of the granite can still crush the cedar (or pine) shims under the cabinets and crack a top.Later,Bass
          4. MattSwanger | Jan 20, 2008 10:55pm | #15
            Thats a good line of thinking.  One that I will remember for the future. Woods favorite carpenter
            basswood | Jan 20, 2008 11:19pm | #16
            Most people won't know or care...but you will impress the granite people. They love a flat, level and sturdy cab install.
          6. MattSwanger | Jan 20, 2008 11:21pm | #17
            They get a level flat surface when I am done.
            I cheat and use my PLS 180 and set the cabinets to the laser line.
            But at times it takes more than a few shims to get them there.  Woods favorite carpenter
          7. calvin | Jan 20, 2008 11:34pm | #18
            I've taken to salvaging the scrap plywood strips we all generate.  I rip them to a uniform size strip.   Have a mark on my small mtr box table and cut 3'' pcs.  These store easily in a cardbd box.  I take this box to cab installs.  In this are stacks of 1/8'', 1/4'', 3/8's, 1/2'', 5/8's and 3/4''.  Instead of building up a stack of shims I'll start with these blocks.  The 3'' (or longer if you want) are wide enough to span two boxes.
            On "bad" conditions I'll run a strip along the whole front toekick line and shim off that.  Run it long and cut off with the MM-see, another use right there.
            I have a smaller box in the van and find several times the need to use these blocks.
            Another case of if you have it you use it.  If you don't, you wonder why.
            But that's the excuse to cart all sorts of #### around.A Great Place for Information, Comraderie, and a Sucker Punch.
          8. MattSwanger | Jan 20, 2008 11:39pm | #19
            My old boss used to have a collection of plywood shims.  We used them alot,  I probably should get back into the habit of using them for kitchens.  Saves alot on shims for really bad floors.
          9. calvin | Jan 21, 2008 12:18am | #20
            It comes out of having a horrible stash of ####.
            At least I'm putting this to some use.A Great Place for Information, Comraderie, and a Sucker Punch.
      2. elicon | Jan 20, 2008 10:28pm | #13
        Jim:Yes, they aren't cheap. But I don't use them exclusively. I still use plenty of wood shims, especially for doors. Where I typically use them is shimming a window or door that sits in a pan flashing, where it probably will get wet at some point. The plastic won't hold moisture or grow mold.
  4. frammer52 | Jan 20, 2008 04:50pm | #8
    unless things are different for harvey windows, vinyl replacement windows do not require shimming.
    1. Toolpig | Jan 21, 2008 04:48am | #21
      These are not vinyl. Wood interior with aluminum exterior.Toolpig (a.k.a. The man formerly known as "Toolfreak" and "Toolfanatic")
      1. scrumseeker | Jan 21, 2008 05:04am | #22
        I needed shims to make adjustments to some aluminum door frames in block openings,  and was worried about the moisture / rot over time.  I came up with an idea to rip shim stock from scrap pieces of Azek,  and they worked great.
        I now keep a box full of various thickness azek shims on my truck.  And it is easy enough to make more or custom size shims as needed.
  5. dovetail97128 | Jan 20, 2008 10:09pm | #11
    I get mine from a commercial storefront and window shop.
    They purchase them by the case lot and I just buy a handfull at a time.
