Plinth block height
| Posted in General Discussion on October 27, 2004 05:42am
Good morning,
I just started to get involved in trim work (I am not a professional).  I am currently looking to install a new door casing using plinth blocks.   The door I have is a standard 30″ door and the ceiling height of the house is 8ft.   What would be the ideal height range for the plinth block?
Jorge
    Sphere | Oct 27, 2004 05:43pm | #1
    whats the hieght of the base board? that determines how high the high the plinth needs to be.
  2. FHB Editor
    JFink | Oct 27, 2004 08:20pm | #2
    Sphere is right, your baseboard has to be chosen first.  I like to use plinths that are maybe 1 to 2 inches taller than the baseboard, but it all depends on the type of room too.  If you have really large baseboard(and other trim) you might want a proportionally large plinth.  In other words, if all the trimwork in the room is exaggerated in size then the plinths should probably be exaggerated as well.
    -Justin
    "If God didn't want me to wear this Led Zeppelin shirt everyday he wouldn't have made them rock out so hard"
    1. fossil | Oct 27, 2004 09:58pm | #3
      I'm remodeling a 1910 home with 10'' tall plinth blocks.  The baseboard is 7 1/4''.  The width is 5 1/2''. 1 1/8'' thick.
  3. gdavis62 | Oct 27, 2004 10:12pm | #4
    Keep in mind that bottom door hinge location when thinking through this plinth block thing.
    I have seen guys special order the doors to move the hinge up a little, to clear the blocks.
  4. woodguy99 | Oct 28, 2004 12:23am | #5
    Like the other guys said, you need to clear the baseboard height.  The other issue is proportion.  Plinth blocks look best, IMO, when the height is 1.5 to 2 times the width.  Ideally 1.6 (the golden mean).
    If your baseboard is 1x4 and your casing is 1x4, a square plinth block would look funny.  Ditto if the plinth is too tall.
      GoldenWreckedAngle | Oct 28, 2004 01:07am | #7
      Good word - 1.61804 if you want to be on the money. :-)>Kevin Halliburton And with that, the great emporer Oz gently floated away on a curtain of hot air, laughing at the unfortunate ignorance of little people beneath him. But under his breath he cursed that stupid little dog...
    2. JorgeW | Oct 28, 2004 07:11pm | #10
      Mike,
      Thank you for your response, I am simply amazed about the amount of great information I have received.
      Currently, the casing will be 1x4 pre- prime-pine (Flat stock).
      I'm was going to mock-up the baseboard this weekend to see if I will use 1x4 or 1x5.  I would like the baseboard to have a larger presence than the casing and therefore started to consider using 1x5.  But, now I am concern that might be too exagerated.  But, I will use the golden ratio to determine  the height of the plinth depending on what I use.
      Therefore 1x4 the plinth height would be approx 5 5/8". (seems kind of short)
      If it is 1x5 them the plinth height would be just over 7 1/4"
      Jorge
      1. fartherhome | Oct 28, 2004 09:51pm | #11
        You cant use 1x plinth with 1x base . plinth should be thicker than the base so the base can die into it.It should also be wider than your casing to look right.
    hammer1 | Oct 28, 2004 01:03am | #6
    I look at both the casing and the base. With plinth blocks you generally set very close to the rabbet. I try to get the casing to balance, equal overhang on each side. I then match the overhang to the height of the baseboard. If the plinth is wider than the casing by 1/2" on one side, I make the height 1/2" taller than the base and cap if there is one. I don't think there are any hard "rules" since there are so many possible molding and design choices. Plinths also look better, to me, if they are thicker than the adjoining moldings, 3/4" molding = 1" plinth.
  6. DonCanDo | Oct 28, 2004 01:21am | #8
    I framed out an opening for a thin in-the-wall radiator and used plinth blocks to make the transition from the baseboard to the casing.  I simply chose a size that looked right.  see picture.
    -Don
  7. GACCDallas | Oct 28, 2004 01:24am | #9
    1/2" above baseboard. Inline with casing or 1/8" reveal. Never flush with the jamb.
    That's what we do unless directed otherwise by the clients.
    Ed.
