PLUMB AND LEVEL PLUMBING
JohnnytheIntern | Posted in General Discussion on February 22, 2022 09:43am
Okay this is a nube question to the n’th degree, but I cant find information on it anywhere.
I’m a draftsman/designer by trade, working on a small home for myself now. I draw and model everything up a thousand times in by drafting software before I do anything. I’m dropping in pipes now  (digitally of course)…
When plumbing/venting, everything connects to the main drain pipe, which is angled a few degrees (mine 4″ at 1.2 to be precise). All horizontal runs should also have a slight slope. I plan on using PVC for everything. My question is with all the fittings at 90, 45 some 22.5, are pipe never “perfectly” aligned? With glue and all it doesn’t matter? Does one slightly nudge vertical and horizontal runs to fit
On this image from a plumbing article, if the trap arm is has slope to how does it fit tightly to the fittings am I missing something?
  1. JohnnytheIntern | Feb 22, 2022 09:48am | #1
    Reference image
    1. mikemahan3 | Feb 22, 2022 12:03pm | #2
      1. These are slip joint fittings and are somewhat flexible. 2. Even if it were level it would either empty into the drain or the trap and not make the slightest difference. 3. Your plumber is not going to pay the slightest attention to your drawings.
      1. JohnnytheIntern | Feb 22, 2022 01:04pm | #5
        Mike,
        1: how about with basic fittings, glue and primer
        2: good point
        3:...i know, i know....
      2. MichaelMahan | Jan 16, 2025 04:58pm | #11
        One of my old identities. I have a bunch that stopped allowing me to post.
    2. calvin | Feb 22, 2022 12:50pm | #3
      What is this in inch per ft?
      1. JohnnytheIntern | Feb 22, 2022 12:59pm | #4
        1/8" per foot
        1. Tim_William | Feb 22, 2022 01:30pm | #6
          Code for drain pitch is 1/4" per foot, I believe.
          1. JohnnytheIntern | Feb 22, 2022 02:06pm | #7
            For 2.5" diameter or less, diameters of 3-6" a slope of 1/8" per foot is the minimum
  2. kojicraps | Jan 15, 2025 02:30pm | #8
    Yeah, pipes never line up “perfectly” when you’re working with fittings, especially with those slight slopes for drainage. The glue gives you a bit of wiggle room, so you’ll usually nudge things into place slightly to get everything snug. As long as the slope is there for proper drainage, and the joints are sealed well, you're good.
  3. abdulhaih | Jan 15, 2025 02:45pm | #9
    Honestly, I’d say don’t overthink it too much in the planning stage. In reality, the fittings and pipes will flex a bit during installation. Even the pros deal with little adjustments as they go. The key is making sure the slope is consistent and nothing is completely out of whack.
  4. stamant1 | Jan 16, 2025 02:06pm | #10
    you are absolutely correct. when installed the angle between the vertical and horizontal is slightly greater than 90 degrees yet the angle of the fitting itself measures 90 degrees. likewise the pipes are cut 90 degrees. when installed the top of the pipe is a tiny bit open from make-up while the bottom of the pipe bottoms out on the inside of the fitting.
