Plumber’s putty or silicone
lekpeter | Posted in General Discussion on April 25, 2007 11:36am
When installing strainers, faucets, etc., I’ve always used plumber’s putty.
Clear Silicone is often mentioned as a better product for the job, and it may be, but what about the film it leaves when you wipe off the excess caused by the squeeze-out??
Is there a product or technique that would help with this?
lek
    RRooster | Apr 25, 2007 11:38pm | #1
    Mineral spirits works, I was told.
    For good new rock music, click on: http://www.wolfmother.com
    BillHartmann | Apr 26, 2007 01:19am | #2
    I use rubbing alcholo. It can be used for "wash" it off the surface and also for tooling it.
  3. andybuildz | Apr 26, 2007 02:01am | #3
    jus' use plumbers putty...all these guys are just trouble makers busting our ballz. Pain in the azz they are...lol
    1. lekpeter | Apr 26, 2007 04:41am | #4
      Andy,
      I obviously find the putty easier to use, but I'll have to give Bill H's rubbing alcohol a try on the silicone clean-up.
      Thanks to all for the replies.
      lek
    popawheelie | Apr 26, 2007 04:48am | #5
    I don't use silicone anywhere any more. The cleanup is only the start of the trouble it causes. When you change the faucet, strainer, whatever,  it is a royal pain to get rid of. If you do use caulking just use the siliconized acrylic caulk. It cleans up with water and later on comes off easier. I absolutely hate silicone.
  5. CAGIV | Apr 26, 2007 05:26am | #6
    Some "Marble" tops can be stained by plumbers putty, I've seen both natural marble stone tops as well as ONXY composite types stain around the drain from using it.
    On ONYX the silicone can be "worked" or rolled off once it has cured.  I've used MS in the past with mixed results.
    Team Logo
  6. CindyTR | Apr 26, 2007 03:33pm | #7
    Acetone might do it. Make sure you keep it off any other nearby plastic, it'll haze it, and mask where you don't want it to go.
    Plumber's Putty would be easier in the long run, sounds like.
    Acetone is the only thing I've found that will allow me to tool silicone. Since caulking is not something I do everyday I haven't developed the skill to lay a nice, even bead. At least with the acetone I can tool it to something acceptable looking.
  7. Link | Apr 26, 2007 06:29pm | #8
    I agree with popawheelie.  I never use pure silicone for anything.  The stuff is a pain to use, doesn't seal any better than a good quality caulk, and if you ever want to remove the faucet it's really going to be a pain.
  8. Shacko | Apr 26, 2007 06:47pm | #9
    Everybody on this post is either right or wrong.LOL.
    "If all else fails, read the directions"
  9. BryanKlakamp | Apr 28, 2007 04:51am | #10
    lek
    If you want to use silicone caulk, use denatured alcohol to clean it and tool it, as well as prep the area to be caulked.
    I prefer using polyturethane caulk. I will not use silicone again. It pulls away from fiberglass, etc., and allows mold to begin growing behind it, discoloring the caulk and turning it black.
    Denatured alcohol works very well with polyurethane caulk as well.
    Plumbers putty? I have removed enough drain tail pieces to know that it will dry and crack. Which is good when you are replacing a tail piece. Easier to clean up the mess. But, not as good for sealing.
    Also, keep in mind that denatured alcohol WILL soften latex paint and remove it. So, if you are using silicone or polyurethane next to paint, remember that.
    Pure silicone cannot be painted. Polyurethane can.
    Bryan
    "Objects in mirror appear closer than they are."
    Klakamp Construction, Findlay, Ohio - just south of the Glass City
    1. lekpeter | Apr 29, 2007 01:12am | #11
      Bryan,
      Thanks for the tips.
      I'm going to try the polyutrethane and alcohol the next time.
      lek
Outdoor Lighting
  • A Postwar Comeback
  • Natural Simplicity
