Plumber’s Putty vs Silicone
user-86517 | Posted in General Discussion on March 13, 2006 09:29am
What is the best product to use for installing drains in sink basins and faucets to sinks/countertops?
Would there be a problem using silicone for everything? Does silicone last as long as putty? What about putting water into the sink before the silicone around the drain cures?
Here’s what I am doing. Let me know if this is correct:
Plumber’s putty: Stainless steel, cast iron, enameled steel
Silicone: Acrylic, Corian, granite, tile
Thanks,
–Andy
    IMERC | Mar 13, 2006 10:57am | #1
    putty stains...
    use siliconized tub and tile... latex based...
    silly cone it out of it's league here..
    WOW!!! What a Ride!
  2. DanT | Mar 13, 2006 11:40am | #2
    You have it right as far as what is recomended.  We use silicone on everything but stainless steel now.  On the less expensive stainless steel kitchen sinks there is often a fair amount of warpage so you have a larger gap to make up.  On that plumber putty seems to work better for us.  Definately don't want plumbers putty on marblite, tile or fiberglass as it will stain.  DanT
  3. SHG | Mar 13, 2006 01:06pm | #3
    plumbers putty will have a reaction to a number of plated surfaces on the faucets as well, especially the higher end stuff.  Always check the instructions for the faucet installation, because it can get pretty expensive if you have to replace a high end faucet.
    SHG
    For every complex problem, there is a solution that is clear, simple, and wrong.
    -H.L. Mencken
Mortar for Old Masonry
