plumbing and cutting into trusses
billybatts | Posted in Photo Gallery on February 25, 2009 02:23am
hey just wondering what one would do in this case…i have an old building built with steel trusses encased in concrete and some type of corrugated metal form.  The toilet drain pipe sits proud of the floor by  the height of elbow the flange is connected to…the floor was built up with six inches of concrete (mud bed) for the tiles to sit on..there is a six inch step UP into the bathroom as a result of this…i would like to cut this truss so that i can lower the toilet drain…there is a view of the same scenario but from the basement and looking up at another persons suite…i am on the second floor so it would be hard to repair this truss.
http://s676.photobucket.com/albums/vv126/billybatts_2009/toilet%20hell/
    jonblakemore | Feb 25, 2009 03:31am | #1
    I would absolutely consult a structural engineer.
    With wood frame structures, a competent builder can sometimes make the same judgment call an engineer would. Not always, but there are prescriptive rules in play that can be quite useful and effective.
    But when it comes to a reinforced concrete structure, I would not trust anyone without a PE stamp and big liability insurance policy.
    Just my opinion.
    Jon Blakemore
    1. billybatts | Mar 07, 2009 02:46am | #9
      it's funny i was using the plumber that the condo uses and he and his guys were scratching their heads about how to do this job, we even brought in a civil engineer and he said it would be cost prohibitive to lower the drain...then i called the plumber that i usually use and he told me to get a 'back outlet'  floor mounted toilet sheeesh so now i dont have to cut into the floor as the toilet flange is mounted on the wall and gets piped about 12" to the stack
      http://www.craneplumbing.ca/db/pdf/38370%20Back%20Outlet%20EL%2012%20.pdf
      here is the toilet, basically every company makes one like it
  2. FastEddie | Feb 25, 2009 04:55am | #2
    Are you sure thsat's concrete?  Looks like spray-on fireproofing.  used to contain asbestos "back in the day".  Done properly, you could cut out the metal deck between two joists and install new deck at a lower elevation supported by two new joists.  but cutting the top of an exisitn joist is a job best left for a plumber with a big butt crack and a  sawzall.
    1. billybatts | Feb 25, 2009 05:06am | #3
      definitely concrete...thanks for your interest
  3. jrnbj | Feb 26, 2009 12:52am | #4
    Man, that's ugly. Where is it? Chicago?
    1. billybatts | Feb 26, 2009 03:26am | #6
      Winnipeg....sometimes they call it 'chicago of the north' haha
      1. jrnbj | Feb 26, 2009 05:52am | #8
        Man, I thought I'd seen just about every type of structure, but that is something else..
        Looks pretty worn out......
  4. draftingguy | Feb 26, 2009 02:12am | #5
    Any idea exactly HOW old that building is?  I couldn't agree more about getting an engineer to come take a look.  Hopefully that doesn't open a big ol' can of worms about the structural integrity in general.
    1. billybatts | Feb 26, 2009 03:27am | #7
      1912
Fast, Accurate Wall Framing
