plumbing for a cement-slab foundation
workalone | Posted in Construction Techniques on December 20, 2003 01:57am
I’m planning a house on a cement-slab foundation. Frost line is 36″ so there will be a perimeter footing unless someone tells me otherwise.
My biggest problem is figuring out the plumbing layout under the concrete. it seem that the required slope angle for waste lines adds up to a pretty deep hole under the slab. Anybody have pointers or can point me to a good book like “Plumbing Cement Slabs for Dummies”??
PaulBen
  1. brownbagg | Dec 20, 2003 02:12am | #1
    go through the wall. But the best book out there is the taunton book at HD and Lowes " plumbing a house"
    The best employee you can have but you wouldn't want him as a neighbor " He the shifty type"
    SamT | Dec 20, 2003 03:57am | #2
    Paul,
    The waste line exiting the house should be below the  frost line anyway, but yeah, you will have some pretty deep trenchs when your all done. Make sure you double triple check all wall and toilet layouts as you set your stubs.
    I usually dig all trenchs to the frost line, slope the pipe up from there to the stubout elbows. Run a good tall vert, wrapped with thin microbubble wrap and tied to rebar stakes. Back fill with sand/pea gravel, packing by foot under the waste lines and to 6" above the lines, then use a vibrating plate tamper with 4"-6" lifts.
    It's a good idea to recheck all slopes after you get the backfill up to the bottoms of the pipes.
    After you know the finished floor grade, set the toilet flanges and any floor drains to grade before you pour the floor.
    SamT
    "You will do me the justice to remember that I have always strenuously supported the right of every man to his opinion, however different that opinion may be to mine. He who denies to another this right, makes a slave of himself to his present opinion, because he precludes himself the right of changing it."   Thomas Paine
Podcast Episode 691: Replacing Vinyl Siding, Sloping Concrete, and Flat vs. Pitched Roofs
Listeners write in about ground-source heat pumps and weatherstripping and ask questions about engineered siding, concrete that slopes the wrong way, and why houses have pitched roofs.
  • A Postwar Comeback
