Plumbing Promblem
MikeMicalizzi | Posted in General Discussion on February 22, 2008 08:43am
Customer has normal pressure on the cold side, but hot side is weak, this is happening at all the fixtures. The hot water comes off the furnace (no hot water heater). Can anyone offer a suggestion as to what could be slowing down the hot water in this situation?
Thanks, Mike
    IMERC | Feb 22, 2008 08:47pm | #1
    suspect water inlet pressure regulator on the boiler...
    WOW!!! What a Ride!
      BillHartmann | Feb 22, 2008 09:24pm | #3
      UH?Now I don't know much about boilers.But the water pressure for the domestic hot water pressure needs to be the same as the cold water. Otherwise you would never get any hot water flow when you have a mix of hot and cold selected..
      1. Gabriel24 | Feb 23, 2008 10:13am | #9
        About three days ago, somebody had the same problem. You suggested change rubber or plastic washers in the faucets and valves because that was causing the slow pressure. This must be the same. The other reason was sediments in the water heater. But, I don't mean to change the subjet, a water heater from a furnace?  Like the kind to warm the house?
          BillHartmann | Feb 23, 2008 04:35pm | #10
          This is ALL fixtures so that it has to be something common to all of them.There is one (or was) "furnace" that also heated the domestic hot water. Lennox Complete Heat. By the dictionary a furnace is just a device that produces heat. But in common uses it's more often used for hot air systems, but really not limited to it..
    IMERC | Feb 22, 2008 08:48pm | #2
    sus;pect heavy mineral deposits....
    WOW!!! What a Ride!
    Sphere | Feb 22, 2008 10:38pm | #4
    Pressure or flow rate? They can be confused easily.
    Fill a one qt pan and time both cold and hot. I am betting you/they mean flow rate.
    Don't know how to fix it, cuz I have the same issue sorta..but an ele heater.
  4. Riversong | Feb 22, 2008 10:52pm | #5
    Yup, that's the problem.
    Since a furnace only produces hot air.
    Perhaps you should source the hot water from the boiler.
    Riversong HouseWright
    Design *  * Build *  * Renovate *  * Consult
    Solar & Super-Insulated Healthy Homes
      BillHartmann | Feb 22, 2008 11:17pm | #6
      "The hot water comes off the furnaceYup, that's the problem.Since a furnace only produces hot air."Not if it is a Lennox Complete heat system..
  5. plumbbill | Feb 23, 2008 12:32am | #7
    Check all valves that lead to & comming from the hot water source. Make sure that they are fully open if they are ball valves & full open & backed off an 1/8 of a turn if they are gate valves.
    How old is the piping?
    What is the pipe made of?
    I'm sure it is a "flow" problem & not a "pressure" problem.
    “The world is a dangerous place, not because of those who do evil, but because of those who look on and do nothing.” —Albert Einstein
  6. rlrefalo | Feb 23, 2008 04:41am | #8
    If I understand  correctly, you have a boiler with a tankless coil. The coil needs cleaning or replacing.
  7. dreadlock | Feb 23, 2008 05:55pm | #11
    if it is set up like a boiler, boilers usually opperate at about 15 psi
Choosing a Paintbrush
  • The New Old Colonial
