Plumbing standards
FRB | Posted in Construction Techniques on December 13, 2005 01:32am
This should be quick and easy for somebody.
What is the standard height for sink stub outs and drains. And how far apart should the stub outs be.
I had somebody, who was getting ready to do my rough in plumbing, tell me there was no such thing.
Was I right to send him home?
Thanks!
Edited 12/12/2005 5:32 pm ET by FRB
  1. dustinf | Dec 13, 2005 01:48am | #1
    Rough-ins measurements should be provided by the GC/builder/designer/architect.  Rough-ins inside a vanity aren't as critical as for a pedestal, but drawer locations have to be considered.  Stud locations, and blocking inside the wall also can affect the location of rough-ins.
    To answer your question, no, there is no "standard" location.  Most situations are unique.
    Swimming through the ashes of another life, no real reason to accept the way things have changed.  Wrapped in guilt, sealed up tight.
    Edited 12/12/2005 5:49 pm ET by dustinf
  2. Mooney | Dec 13, 2005 02:01am | #2
    I dont remember a height but it does make a difference.
    Depending on depth of sink and trap depth that you have to be under or of course it would not work .
    16 ionches from the floor is about minimum.
    Stub out drains are normally center or close to, but Ive seen several offest. We normally T off anyway so that determines distance of hook up and not the stub out it self which is not critical.
    I like 16 off the floor to allow good flow from the dishwasher . Ive seen them as high as 24 inches  from the floor.
    Tim
    Edited 12/12/2005 6:03 pm by Mooney
    1. FRB | Dec 13, 2005 03:23am | #3
      The plumber I've used before always put them the same height and same width apart. I thought. but wasn't sure, it was 16" up and 12" apart with the drain centered. I guess that was just his rule that he lived by.
      I better call my new plumber back and apologize!
      Thanks again.
      1. BobKovacs | Dec 13, 2005 03:52am | #4
        Most manufacturers have rough-in sheets for their fixtures.  They're especially critical for pedestal sinks, where you're trying to tuck the plumbing behind the pedestal.  In a vanity, I'd be a little more flexible.
        Bob
  3. plumbbill | Dec 13, 2005 08:20am | #5
    Sink & lavs differ cause of different counter heights bowl depths so on & so on
    Spread 8" & 10" are most common I prefer 10 gives ya a bit more room, heights of those are usually just above the waste stub
    16" to 20" are most common  I would rather be at 18" for lavs & add a longer tail piece than be too high & turning a trap around to get it to hook up.
    I like 16" for kitchen sinks cause of deep bowl sinks, garbage disposals & branch tail pieces for dishwashers. You start stacking all that stuff in line & then you wished the stub-out was lower
    1. BillBrennen | Dec 13, 2005 09:54am | #6
      "You start stacking all that stuff in line & then you wished the stub-out was lower."LOL how very true!Bill
Drafting the 2027 IRC
  • The New Old Colonial
