I need to re-plumb my house since I have experienced 9 pin hole leaks in my copper piping. House is 10 years old and I had all the water tests done. I am considering using aquapex manufactured by Wirsbo. Has anybody had any problems using aquapex. If so I would like to know what problems you encountered and what corrective action was required. Thanks in advance.
Veneered wall paneling is popular for its clean style, but it's a surprisingly complex trim carpentry job to do well.
A Modern California Home Wrapped in Rockwool Insulation for Energy Efficiency and Fire ResistanceRelated Stories
Post over at Breaktime - I am trying to remember the exact reason, but the pinhole leaks may be a product of your waterheater.
My plumbers are using it almost exclusively now. Even quick add-ons and alterations they are changing to "Pex". It is especially good in possible freeze locations"crawls spaces and seasonal cabins". There they sometimes put a smaller fluid line inside a larger static air filled line as a sleeve which is open on the ends allowing some warm air flow , It is working great.
Interesting, I'm in the process of replumbing my house with copper. While doing this the city built a new water tower and had a reverse osmosis system installed at the water plant. I had heard that the reverse osmosis system can be hard on copper pipe or more so the joints. I understand that the process removes all the minerals from the joints and develops leaks. I understand that the water treatment plant adds minerals after the process to help with this. My plumbing project went on hold to see what develops around town with copper pipe.
RU
