Plumbing Vent Problem
FairviewTim | Posted in General Discussion on January 27, 2013 09:01am
Good Day Folks,
I have a problem with a vent pipe on a bathroom creating a nasty smell on our deck when it’s cold out. It seems inversion is bringing the smell down to deck height and when we’re in the hot tub on cold evenings it’s obnoxious. The vent is approximately 14 feet from the hot tub.
Is there anything you all can think of besides rerouting the vent to a higher location? Doing so would necessitate cutting into the ceiling as the attack space above this bath is only 3′ at the peak. I’ve looked at air admittance valves but I don’t think this will work on the exterior.
Thanks so much!
Tim
  1. user-1116010 | Jan 27, 2013 11:00am | #1
    charcoal filter
    Tim,
               There are several plumbing vent cap devices that filter or mask the odor, google " Sweet Air ".................... MikeL
    1. FairviewTim | Jan 27, 2013 05:04pm | #4
      charcoal filter
      Thanks, Mike! This looks promising!
      Cheers,
      Tim
  2. DanH | Jan 27, 2013 02:22pm | #2
    Yes, you definitely should not put an AAV on the external vent -- that could be dangerous.
    It is a little curious, though, that the smell is so bad.  Do you have a septic tank, or are you on sewers?
    1. FairviewTim | Jan 27, 2013 05:02pm | #3
      Thanks for the reply, Dan. It's a septic system and this is the closest vent to the tank.
      Tim
      1. DanH | Jan 27, 2013 06:13pm | #5
        If you haven't had the tank serviced in a couple of years you might want to have someone check it.
      2. junkhound | Jan 27, 2013 07:07pm | #6
        Simple, put a cap on the vent when you are in the hot tub, esp if a septic system. You probably dont even have to worry about aspiration sucking the water out of a trap if just for short term capping.
        1. DanH | Jan 27, 2013 07:38pm | #7
          You do have to worry about going back in the house and discovering it filled with phew.
        2. calvin | Jan 27, 2013 07:44pm | #8
          Great Idea
          go up on the roof every time you want to go in the hot tub.
          How could something be so simple.
  3. rdesigns | Jan 28, 2013 09:15am | #9
    You might also be able to encourage the flow of air in the vent system to go elsewhere if there are other vents thru the roof, like maybe enlarging and raising a vent that is closer to the highest part of your roof.
