Plumbing: venting a tub…
| Posted in General Discussion on May 22, 2000 07:23am
I’ve had to substantially lower the horizontal break of the vent trap arm
to accomdate a longer tub. In effect, it is much closer to drain height
now. I know the code in most places says 6″ above overflow line for a
fixture. Can someone please explain the importance of this rule in a tub
and what impact is created as that height descends? Thanks. David Be
  1. Guest_ | May 22, 2000 07:22am | #1
    I believe they're worried about "stuff" -- which could be coming
    from some higher fixture than the tub -- getting trapped in the
    vent
    and plugging it. The six inches is the safety margin.
    Could you install a 45° to avoid the horizontal?
