Plywood ceiling?
smllr | Posted in Construction Techniques on April 12, 2009 09:13am
Greetings,
I plan to use thin plywood (1/4″ or so) in ceiling some garage bays in an outbuilding. Can I get by using my 16-gauge finish nailer to attach the plywood if I shoot the nails in at an angle? (I’m worried about the small heads on the nails).
Thanks in advance for any help.
Steve
  1. KenHill3 | Apr 12, 2009 09:20pm | #1
    Not a very good way to attach 1/4 ply, too easy to shoot/pull through. You may want to add some construction adhesive if you you really gotta use the 16ga nailer.
    Attaching ply with small-headed nails is just not very reliable. A narrow-crown staple gun would be perfect.
    1. smllr | Apr 12, 2009 09:25pm | #2
      Thanks for the prompt reply. You gave me the answer that I was sort of hoping for -- an excuse to buy a new tool.
      1. JMadson | Apr 13, 2009 02:15am | #4
        The staples will also make the job a whole lot easier. Two or three well placed staples and you can let go of the board, especially 1/4" ply. I agree though that 3/8" will look better.
  2. Piffin | Apr 12, 2009 10:45pm | #3
    Use at least 3/8" unless you are going for the saggy baggy look and some real nails or screws.
  3. BilljustBill | Apr 13, 2009 02:43am | #5
    If the attic is vented and moisture flows in and out,and
     if you are on 24" centers, it's really going to sag...  More so on days of rain or high humidity...  1-by material for strapping on 16" centers might help, but using adhesive will help.  Lowe's is running sticks of PL-200 adhesive for $1 each.
    The thicker, the better, but remember thin plywood is just kindling if a fire breaks out and you'll have no fire barrier between your stuff and the roof...
    Bill
    1. smllr | Apr 13, 2009 03:23am | #6
      Bill,Actually the ceiling will be for the lower level of a two-story building that's 65+ years old. The joists are 4*6s on 16" centers. I am planning on insulating between the joists and using the plywood to keep the critters out.
      Edited 4/12/2009 8:42 pm ET by smllr
        BossHog | Apr 13, 2009 03:30am | #7
        I'd be less worried about sagging and more worried about fire spread in a garage.
        Organized people are just to lazy to look for things.
        1. smllr | Apr 13, 2009 03:39am | #8
          The garage bays will not have doors and I'll be using the bays to store my riding mower and an ATV. What material would you suggest that I use for the ceiling?Thanks,
          Steve
            BossHog | Apr 13, 2009 05:06am | #9
            Drywall is at least not flamable. It's not a prefect fire stop, but it doesn't contribute to a fire.
            Money isn't everything. But it sure keeps the kids in touch.
          2. AitchKay | Apr 13, 2009 05:13am | #10
            Ditto.AitchKay
          3. BillBrennen | Apr 13, 2009 09:59am | #12
            Double ditto. Drywall is cheap and perfect for this application.
            Dam_inspector | Apr 13, 2009 05:36am | #11
            Someone once suggested a metal material used on pole barns. I don't think it was siding or roofing but could have been, I remember it was fairly light and white.http://forums.taunton.com/tp-breaktime/messages?msg=30984.2
            Edited 4/12/2009 10:40 pm ET by Dam_inspector
      2. rdesigns | Apr 13, 2009 06:26pm | #13
        Because of the 2nd floor above, which I assume will be living space, it is critical to use drywall for the ceiling as a fire barrier. Not that it will absolutely stop fire spread, but it will slow it down to buy more time for escape and/or fire fighting.
        Today's codes actually require such a fire barrier, not just for ceilings, but for garage walls if there's living space on the other side.
        1. smllr | Apr 13, 2009 08:49pm | #14
          Thanks for the info. The building is actually an old barn/grainery. I'm going to use the second floor as a shop.
Fast, Accurate Wall Framing
