Plywood over radiant floor heat
196119941998 | Posted in Construction Techniques on September 9, 2009 03:38am
I have been working on a project and owners would like to put 3/4 inch plywood cut into 12 inch wide painted strips to simulate flooring. Any ideas on how it will react with radiant floor heat (fast trac) and fastening ideas?
Edited 9/8/2009 9:06 pm ET by 196119941998
  1. surujunah | Sep 09, 2009 03:51am | #1
    i'd say that thinset mortar would be a good bond for the plywood. make sure and get the polymer modified stuff to allow for more flexibility. and use a marine grade plywood so the glues are of higher quality. the paint is where i would be concerned, however. movement and heat can't be too kind to it. maybe a special porch and floor enamel would be better? good luck.
    Jeff_Clarke | Sep 09, 2009 08:03am | #2
    I'd say that this is a really bad idea and would try to talk them out of it.
  3. TomW | Sep 09, 2009 09:17am | #3
    I'd face nail it down, fill the nail holes and paint it. If the system is designed well the temps won't be all that high and you wil;l have less movement with plywood than with a solid  wood floor. I did 7" wide pine over radiant heat and have had no problems with it.
    1. Piffin | Sep 09, 2009 02:36pm | #4
      same here.Normally I would use glue too, but 99.9% of people will be unhappy with this look after a year or two and will want to tear it up, so the nails is good.
  4. wane | Sep 09, 2009 03:04pm | #5
    there is a laminate around just like that, 12" wide, couple of different colors, snap, click ... plus I'd hate to hit the heating with a fastener ..
  5. Clewless1 | Sep 09, 2009 04:22pm | #6
    Plywood should be really thermally stable relative to many other floor materials (e.g. solid wood). What are you doing w/ the edges of the plywood? That could be an area of problem from a finish and user standpoint (i.e. slivers). Maybe just knock the edge off w/ e.g. sander or planer? After it's painted, it will be OK?
  6. Danno | Sep 09, 2009 07:49pm | #7
    I'd worry about all those splintery edges, esp. when cutting plywood into 12" strips. What about just routing fairly shallow grooves to make the "strips"?
A Practical Perfect Wall
  • The New Old Colonial
