Pocket Door
detroitbob | Posted in Construction Techniques on July 26, 2003 05:50am
I have an 1959 home with pocket doors that need refinishing.  I have not removed any of the trim.  I want to take the doors down to refinsh.  My question:  What do I have to remove/do to at least reveal the entire door and then take it down?  Thanks for the help.
  1. steve | Jul 29, 2003 03:41am | #1
    remove the jams and remove the doors as needed
    pocket doors are an aberration and a pain
    caulking is not a piece of trim
  2. Piffin | Jul 29, 2003 04:18am | #2
    it'll depend on the type of hardware and it's access profile.
    I install Johnson hardware and I put the header casing and jamb liner in with a couple small screws to make it easy to get at later. I still use vinyl spackle over the screw so You have to look for a shadow line.
    Occasionally, I can get a door off withoiut removing the trim. With these modern Johnsons, a nylon lever locks the atachment above and you can reach it to release it with a screwdriver or other small tool.
    Some of the hardware from a hundred years ago requires removing a split jamb at the side where the door pockets into the wall to get at the releases and adjustments.
    in '59 I don't know.
    But I'll bet the local shop class could have fun with it.
