Pocket Door installed @ top of staircase
j99t99 | Posted in Construction Techniques on March 10, 2008 05:09am
I have a door in the kitchen, leading to my basement and I would like to replace it with a pocket door.  Is this acceptable?
Another fact, when you travel down the stairs from the kitchen, there is a landing after 3 stairs, which has a door leading out of the house.  I think that should be sufficient from an egress standpoint.
I live in union county NJ.  Any forseeable code violations?  My other option is to use a folding door (however not a louvered door).  The objective is to limit the amount of footprint the motion of the door takes up.  Any feedback is appreciated.
Tim
    Matt | Mar 10, 2008 06:27am | #1
    I think you will be fine.  The main thing is that you don't want a door swinging out over the stairs - from a functionality standpoint.  Even that is not goverened by code, as long as it is not the main egress door for the home.
  2. DonCanDo | Mar 11, 2008 11:32am | #2
    The only downside I can see is that basement doors should remain closed for safety, but all of the pocket doors that I've seen in all of the homes that I've been in have been open and normally remain open unless there is some compelling reason to close them such as a brief need for privacy.
    Hinged doors are a lot easier to keep closed because they're a lot easier to open and close in general.  Your habits may be such that you know you'll keep a pocket door closed, but it's something to consider.
    1. Biff_Loman | Mar 11, 2008 05:22pm | #3
      Yeah.  Serious pain if you open and close them daily.  Flip out the little handle. . .  bleah.
        j99t99 | Mar 11, 2008 09:08pm | #4
        I know what you mean about the opening and closing.  Actually this door will be opened and closed frequently.  We are trying to limit foot print and are willing to sacrifice with this option.  Otherwise I am going to use a bi fold which I think look can look hideous, plus they limit the opening of the doorway.
        It looks like we are moving in the direction of a pocket door.  The layout of the house is quite peculiar, but alas it is all we can do.
        Thanks again for comments.
         Tim
        1. Biff_Loman | Mar 11, 2008 09:10pm | #5
          Bifolds?  Yikes.
          1. fingersandtoes | Mar 12, 2008 06:06am | #6
            Yikes indeed!
          xxPaulCPxx | Mar 12, 2008 09:26am | #7
          I'm planning on installing a pocket or exposed face slider at the top of our stairs to limit noise transmition when I open up a wall later on.Rebuilding my home in Cypress, CA
          Also a CRX fanatic!
          If your hair looks funny, it's because God likes to scratch his nuts.  You nut, you.
  • A Postwar Comeback
  • Natural Simplicity
  • A Grand Rescue on the Coast
