I am having a difficult time finding engineered plans for a large (24′ x 30′) pole shelter to use as a carport. Can anyone help refer me somewhere?
Understand lumens, ceiling brightness, beam spread, tilt, and color options to make a wise choice on a common fixture that can range from $75 to $750 or more.
It is not a terribly difficult structure but since you require engineered plans, I assume that your local permit agency requires engineering.
That would mean that it needs to be engineered to a certain set of required specs.
In Mountains there is a high snow load to design for.
In Florida, there is a high wind load to design for.
In short, you need someone local or you need some design parameters to start with.
Thanks for responding. You're right on with the permit and development office. I'm a good "common sense" engineer but the permit office doesn't lean highly on common sense. one question I seriously need answered by the way is if the posts should be cemented into the ground (say w/ .60 treated)below frost of course for shear strenth. I'm in Iowa by the way. I'm afraid cason type footings w/ posts bolted on top would add a shearing problem only solved through cross bracing or cables, and I would like to keep my exterior as open as possible. it's in a valley, and the wind, snow and dead loads have been taken into account. It's mainly the posts (8x8's) I'm in question about. Thanks again, Dave
You are right that mounting the poles atop piers would kill your shear strength and eliminate one of the primary reasons for building with poles.
I normally never set a post in crete. It just gives the frost an irregular surface to get a grip on.
Sorry, it still sounds like you need a local guy to satisfy them..
twogroovy, are you a gambling type person??, do you have a little/lot of time on your hands?? In my 1982 ubc, chapter 23, some info. I did oh, lets say, a lot of time spent, researching wind gusts, then the city told me look at chapter 16. As I was told on this forum, it's not that simple, well, twogroovy, I will tell you myself, "It's not that simple". I would suggest, if you are comfortable with the math, research and your plan, of your pole barn, present it to the governing body, right around 9:00 am, ask them politley for an overview/ plan check, of your "proposed pole barn" prior to start. Did I ask you if you were a gambling person? Jim J
One of my all time favs, was a place called Sues Rondezvous. Five stages, two girls per stage.....they often had to share the pole.... wink, wink, nudge, nudge!
We don`t call em "pole shelters" round here.....we call em "gentlemans clubs"....I like your name though....got a nice ring to it. Bet it throws the old ball and chain off the scent a bit, no?
J. D. Reynolds
Home Improvements
"DO IT RIGHT, DO IT ONCE"
That's pole barns and the place you're talking about was in Tiajuana.
That wasn't Sue's Rondevous of Mt.Vernon NY was it?
ROFLMAO!!!! In a million years I never woulda thought anyone here would have heard of the joint (maybe WorkshopJon but even that was a long shot!).....howdy neighbor, where ya from?!J. D. Reynolds
Home Improvements
Born and bread in the Bronx...Morris Park Section.. Now live in northeastern PA
Work as a New York City Housing Authority carpenter supervisor..and went to a few bachelor parties there..matter of fact one of the maintenance guys I work with is a "bouncer " there a few nights during the week. How about you? where you from where are ya now?
Born and raised in Pelham....liked it so much decided to raise my own family here.
I haven`t been to Sue`s in ages, but it was a regular stop in my younger days. Used to be a place just over the bridge in the BX, Pretty Woman?, that was fun to visit as well...dunno if its still there. Lots of them are shutting down in this neck o` the woods....allegations of prostitution. But I swear 'Nothing goes on in the champagne room!'J. D. Reynolds
Home Improvements
We have a place here called "The Lumberyard". Throws the old ball and chain off every time. By the way our upper crust clubs, I refer to as breast lounges. love to see the wheels rollin' when I suggest that one.
