Polishing Marble Tile Edges
dccarp | Posted in Construction Techniques on December 5, 2002 05:59am
I’m working with marble for the first time and am wondering what to do about the exposed edges that are not polished .  The project is a  shower enclosure.  There are a number of outside corners that I’ve lapped, which leaves the edge of one tile exposed.  What would be an easy way to polish these edges without purchasing an expensive tool which I probably won’t need for another five years?  Has anyone tried  something as simple as polyurethane?  Thanks for any input.
  1. exchef | Dec 05, 2002 06:29am | #1
    the best tool or that is a 4inch grinder the only hitch is you need the variable speed because you should polish at about 2000rpm when i worked in a granite and marble shop i spent alot of time with a millwauke that preformed great on the lowwest setting as for poly on granite tile edges we would polish them with the coarse grits(3 out of 6) and then run tounge oil but for marble it polishes in 3 or 4 grits 80 to shape 120,240,400 and that was it you also may want to seal the marble as it is pouros
    noah
  2. andybuildz | Dec 05, 2002 09:57am | #2
    Dan
        I'm guessing you have a wet saw......right? What I do is I miter all the outside corners so that I dont have butt ends showing but in cases where I do.....I tediously sand the edges with a fine grit paper. The finish on marble isnt  coated but rather a fine sanding and buffing. What you can do to make life easy is to take the tiles you will have exposed butt eges on and bring them to a tile/granite shop to have them polish em up.
    Have fun
            Namaste
                      Andy
    It's not who's right, it's who's left ~ http://CLIFFORDRENOVATIONS.COM
  3. r_ignacki | Dec 05, 2002 05:35pm | #3
    you can get satisfactory results with some hand polishers, get them at the supplier.
    Need lot's of elbow gease.
Podcast Episode 691: Replacing Vinyl Siding, Sloping Concrete, and Flat vs. Pitched Roofs
Listeners write in about ground-source heat pumps and weatherstripping and ask questions about engineered siding, concrete that slopes the wrong way, and why houses have pitched roofs.
  • A Postwar Comeback
