Poly dry time — how long is too long?
user-128445 | Posted in General Discussion on May 27, 2006 05:56am
I’ve applied a first coat of polyurethane to my floors, and had hoped to add a second coat this morning — so I can go away for the weekend. It’s still not dry, and am wondering if I were to let it cure over the weekend (3 days) if applying a second coat after this much time would be a problem. Any comments?
  1. brownbagg | May 27, 2006 05:59pm | #1
    humity will slow drying
    1. andybuildz | May 27, 2006 10:17pm | #6
      humity will slow drying>>>>>>>
      Now in the good ol' daze of moisture cure you get a real nice buzz andddddd it dries within hours on rainy dazeeeeeee ~~~Yeeee haIf Blodgett says, Tipi tipi tipi it must be so!
      TipiFest 06~~> Send me your email addy for a Paypal invoice to the greatest show on earth~~>[email protected]
  2. calvin | May 27, 2006 05:59pm | #2
    I hope you stirred well before and during application.
    Did you thin down the first coat?
    Recoat should be no problem , lightly sand and vac and tack.
    Quittin' Time
  3. hmj | May 27, 2006 07:07pm | #3
    water or oil based? Water is usally ready to recoat in 2 hours or less, depending on humidity. Oil can be a bit longer-overnight... If it is at all tacky, wait longer.
  4. jimblodgett | May 27, 2006 07:19pm | #4
    What do the instructions say?
    Tipi, Tipi, Tipi!
    http://www.asmallwoodworkingcompany.com
  5. andybuildz | May 27, 2006 10:15pm | #5
    It sounds to me like youre talking about recoating without sanding. Is that right? With water base finishes you can do that but not with oil really. And with water base read the directions on the particular finish youre using and see what that company recommends. If it doesn't feel dry now forget it. You'll have to wait the few days and use a sanding "screen". If the floors not too big you can do it by hand other wise you'll need to rent a buffing machine from a rental place and buy a screen from them.
    a...
      zak | May 27, 2006 10:57pm | #7
      My oil finishes (flecto, varathane for floors and 99 for other woodwork) say that if you recoat between 12 and 24 hours (or therabouts), you don't need to sand.  If you wait longer, you should sand.
      I usually only sand between second and third coats, when doing 3 coats.  More sanding wouldn't hurt though, and it doesn't take long.zak
      "so it goes"
  6. Floorman | May 28, 2006 12:16am | #8
    One thing that one will learn over time is to let it dry fully before you try to coat again. It should powder up nicely when you sand between coats. I always let oil dry one day between coats. 1st coat Monday, 2nd coat Wed. and final coat Fri. That is for oil. Waterbase. Mon,Tues, final Wed. You can't push drying. Ones that do it for a living learn this lesson by losing money.
  • A Closer Look at Smart Water Leak Detection Systems
