poly ethelene connection
stvfwt | Posted in General Discussion on July 10, 2007 06:42am
I need to “T” into 3/4″ black poly ethelene flex water pipe, ~ 60# psi.  I tried a compression T but it seperated after a few days.  I’m not use as to how tight to make the connection.  Is this the best approach or will a barbed T work better?   Other ideas?
  1. Shacko | Jul 10, 2007 06:50pm | #1
    BARBED!
    "If all else fails, read the directions"
  2. DanH | Jul 10, 2007 06:58pm | #2
    A barbed T with two hose clamps per leg. Pour hot water on the ends of the pipe first to soften them up. Have a buddy there to help you push the parts together.
      Luka | Jul 10, 2007 10:41pm | #7
      And each pair of hose clamps should end up with their heads on opposite sides of the pipe.r/l r/l, l/r l/r, r/l l/r, l/r r/l, whatever... As long as any two consequtive hose clamps have their heads on opposite sides of the pipe. Or at least a third of a rotation away from each other.
      Yeh... That'll work.
      1. DanH | Jul 10, 2007 11:17pm | #8
        Yeah, otherwise the feng shui just isn't right.
          Luka | Jul 10, 2007 11:44pm | #9
          Yeah, well feng you too, buddy !;o)Offsetting the heads of the hose clamps is an old automotive trick I learned decades ago. It lowers the risk of a leak.
          1. DanH | Jul 11, 2007 12:05am | #10
            Yeah, I can see that -- lessens the chance that excess diameter will be "bunched up" all on one side.It's just that I like the look of having the clamps all neatly in a row, standing at attention.
    IMERC | Jul 10, 2007 08:17pm | #3
    barbed T with double hose clamps...
    WOW!!! What a Ride!
      BillHartmann | Jul 10, 2007 08:20pm | #4
      Thermofusion is better.But I don't think that Bosch makes one..
        IMERC | Jul 10, 2007 08:25pm | #5
        they make a heat gun...
        that is at least a start....Life is not a journey to the grave with the intention of arriving safely in a pretty and well preserved body, but rather to skid in broadside, thoroughly used up, totally worn out, and loudly proclaiming<!----><!----><!---->
    DDay | Jul 10, 2007 08:41pm | #6
    This is what the supply house carries in my area, they work with compression fittings and the sleeves. These are rated to go underground for the supply line for the house, so it might be overkill for what you want.
    http://www.fordmeterbox.com/pages/J_Section/Jsec.htm
