Polyurethane over painted floor???
Espo | Posted in General Discussion on November 8, 2006 03:42am
Hi All,
We recently painted our bathroom floor using the premium Sherwin Williams floor paint (I forget the name of the product). After a few months of use and several moppings, the satin sheen is mostly gone. I’m wondering if we repaint, let cure, and then polyurethane would we have a better looking, wearing floor in the long-run?
Thanks,
Dave
  1. sharpblade | Nov 08, 2006 04:47pm | #1
    Use water based poly.
  2. Dave45 | Nov 08, 2006 05:06pm | #2
    Why don't you run this by the Sherwin Williams folks?  A real paint store could probably give you several workable solutions.
    DISCLAIMER: This approach may not work with other paint brands (e.g. Behr).  I'm reluctant to ask anyone wearing an orange apron for anything more complicated than the time. - lol
    JDRHI | Nov 08, 2006 05:40pm | #3
    Yep.
    Give it a good four or five coats being a high traffic, moisture prone area.
    FREE SPONGE BOB,SANCHO PANTS!
  4. DonCanDo | Nov 08, 2006 07:02pm | #4
    I just took a look at a can of Zar water-based poly.  It specifically recommends their oil-based poly for high traffic areas.  I think a bathroom qualifies as high-traffic.  Unfortunately, oil-based poly will cause a greater color change than water-based.
    On the other hand, I used water-based poly on the oak floor in my hall (medium traffic) and it's holding up fine.  Of course, that's poly directly on wood.  I would be a little concerned about adhesion since your painted floor does have some sheen to it.
    So, no answer, but maybe something to consider.
    -Don
    1. johnharkins | Nov 08, 2006 09:26pm | #5
      couple things
      if you wanted that floor to glisten why weren't you in the semi gloss to gloss in the first place?
      Maybe etch the surface slightly & coat w/ gloss of same materialhere in Northwest Rodda Paints produces a fine Poly based paint that I use all the time on ext surfaces if they are worthy of a brilliant finish
      not sure of Sherwins offerings in that department but many of the nationals have been discarding such solvent based products due to environmental concerns ( led by California )would think glossier is answer & you'll be coating it say every two yrs to maintain some gleam
