Has anyone used those new Pony clamps for face frames?
http://www.adjustableclamp.com/sp-8500.htm
Beyond just general impressions, I’m wondering about the hole that allows you to drill pilot holes and insert fasteners while the clamp is still on. How big is that hole? (Nobody stocks them up here and I’m working from catalog descriptions only.) Can you countersink or counterbore for a good sized screw head?
Thanks in advance!
Tim
They work just fine; theres a plastic wing that flips out of the way so the driver bit and screw head will go thru. But I dont think you'll counterbore anything through there. Never tried. Always use trim screws there.
"Sometimes when I consider what tremendous consequences come from little things, I am tempted to think -- there are no little things" - Bruce Barton
They are worth the money. I think I paid $50 for the pair. The hole in the side of mine is 3/8". The plastic flap in mine has a small hole for predrilling pilot holes. Open the flap and put a small countersink to it then screw it and remove the clamp.
You're entitled to sh!t.---Tony Soprano
Tried them and returned. Not impressed for the money. A good one handed clamp helps better.
They're not bad, but you'll still need to augment with other clamps for a typical installation.
As mentioned..... yes, you can pilot, countersink and set with the clamp in place.
I believe they now also make a clamp for Euro-style cabinets as well
As any tool you'll get many different impressions.
I have had a pair for a number of years and think they are much better at joining and lining up faceframed cabinets for fastening. The flip thing I never use. I eyeball center a Fuller counterbore with tapered bit. I use full headed screws, by habit I suppose. They tighten and align (on the face) as described in the literature. I wouldn't be without them. I would like three, but they are sold in pairs. I make due with the pair. I draw them up together (not snug) then use the face alignment clamp to even the faceframes. Then lay on the joining clamp tight. Bore the hole, run the screw in, then remove the clamp.
As would be the case, since buying the euro pair, I haven't had a frameless install since. On the one vanity system I tried them on, not quite as impressed as with their frame brethren.
If you are serious about cab. install and do a few kitchens a year, check out the Third Hand cabinet jacks from Fastcap.
Quittin' Time
We use them on every cabinet job, but find it easier to not mess with drilling, countersinking, and driving screws through the small hole in the clamp (we put trimheads in above or below the clamps.
Quick clamps are too wimpy to do a good job holding faceframes together.
We often leave the Pony Cabinet Claws on ganged up cabinets while we lift them into place.
I got a pair for installing my kitchen (my 1st). I found them very helpful, but I used trim heads so there was no need for counter sinking. Maybe a pro could do just as well with a simpler clamp, but I didn't find any real faults with them. They were worth the $50 even if I only use them once.
I've had a pair for 5-6 years now and I love them. I also don't bother using the hole in the clamp, just drill and drive a trim head just above or below the clamp. I've been using GRK trim screws lately and have been real happy with them. I'm wondering what kind of screws others use? A little pricey, but never had one strip or break.
Kimball
You all that are using trim head screws -
Do you not have to countersink the heads at all even in hardwood?
What bit/bits do you use to predrill - tapered or not?
Do the trim bits tend to break more often?
The cabs I've seen around here with trim screws in them , the screws are countersunk and puttied over. Is this done by countersinking (with what?), or by driving the screw itself?
Inquiring minds want to know.
"Citius, Altius, Fortius"
Heck, I use a staight bit the size of the trim screw shaft to pre-drill and it sets itself into the edge of the face frame. Works with oak and maple cabinets. As I said, I haven't had any trouble with the GRK trim screws breaking. These are brass screws and I usuallt don't putty teh holes. Hide them behind hinges when I can. Hope that helps.
Kimball
Has anyone ever tried pocket hole screws for joining the face frames? I'm not taking about drilling a pocket hole but rather just normal holes for the face frames then using the pocket hole screws. I think the pocket hole screw's pan head or washer head would clamp nicely and pull the frames tight without the possibility of over driving the screws and splitting the face frames.
If face frames are clamped together well, trimhead screws work great. I try to avoid using large-head screws for such a visible location.I use 1-1/4 pocket-hole screws to hold laminate c-tops down to the 1x4 build-up. Nothing works better.
Here is another use of pocket hole screws in cabinet installing...to keep ganged up cabinets straight--I shim and use pocket hole screws between the cabinets at the back (after clamping a straight edge across the fronts).
That's a nice idea to deal with wavy walls. I really like the clamping ability of the pocket hole screws, they really hold very well.
I do the shim and back screw pretty much on every run of cabs ...
but I'd not waste the more expensive pocket hole screws ...
I just run a coarse thread drywall screw thru.
holds just fine for that application ... cheaper and easier to find.
even if I run outta shorter screws ... run a 2" ... and if it's gonna be left open and I'm worried about someone snagging their hand just snap the point off with a hammer.
Jeff Buck Construction
Artistry In Carpentry
Pittsburgh Pa
Jeff, I was going to say the same thing. I always screw the backs together with drywall screws. This helps to get a straight line in the front and holds it all together.
Kimball
I used to use drywall screws too. The pocket hole screws cost about 3 cents each IIRC. They hold onto a square drive bit nicely, go into wood easier & faster & hold better. I spend an extra 50 cents or a buck per kitchen, but I like using them much better. I use the Kreg jig on almost every job, so I always keep them on hand.
Basswood, what brand of t-10 bits are ya using for the trimheads? I love them little GRK's, but the bits are kind of the weak link in the system. The best ones I've found so far are the GRK brand. I try to keep plenty on hand. Just wondering if there are any better ones.
Mike
I use GRK bits too. Color coded for dummies...helps me tell the T-10's & 15's apart without looking too close.My bits last much longer now that I make tiny trimhead countersinks (especially if working with hickory or maple cabs). I use the first two steps of a Unibit--makes a perfect countersink very quickly. Now, I seldom break a T-10.
We use 3 2-1/2" GRK trimhead screws on each cabinet rail (top, middle, & bottom). I do make a small countersink for the trim head...it makes the T-10 bits last much longer.The Irwin step-drill bit makes perfect trimhead countersinks...far fewer broken screws and bits, especially in hickory or maple, etc.
Hey Basswood,
Where do you buy your GRX trimhead screws - somewhere local or have them shipped?
Also would like more info on the Irwin Step Bit you use.
Thanks,
Shoe
I have two local suppliers for GRK in Winona, MN (TriMac Do It Best & Kendal Lumber True Value). Are you near a Scherer Bros.?http://www.grkfasteners.com/featured_retailers.htmI'll take some pics of our method and post them next week. Here is the bit we use for trimhead countersinks:http://www.amazon.com/gp/product/B0002BC0Q4/sr=1-7/qid=1143593943/ref=sr_1_7/002-6415708-6874437?%5Fencoding=UTF8&s=hi
The unibit is what first came to mind when you mentioned step bit - just wanted to confirm.
Thanks for the GRK link. I am near a Scherer bros - might have to stop in
Look forward to seeing your pics,
Shoe
Edited 3/29/2006 8:59 am by Shoeman
Here is what we use for the trimhead countersink. Two steps up this Unibit works great for the 1-1/2" to 3-1/8" GRK's. When we use the 5" trimheads we go to the "third-step."
I use these with an additonal round pad welded on to the swivel base, just like on the Krieg tool clamps
http://www.irwin.com/irwin/consumer/jhtml/detail.jhtml?prodId=IrwinProd430012
Had 'em for years...and love 'em!
Buy two pairs, even if you're only able to use three at a time....worth the extra $50.
J. D. Reynolds
Home Improvements
Thanks everybody. That's the sort of consensus I like to see. I'll order one pair now and some more next time I'm feeling flush. I tell my wife that tools don't count. "They're deductions, Honey, deductions."Tim
