Pool apron advice
| Posted in Construction Techniques on June 13, 2005 09:46am
I’m sure I will get an answer I trust here.
I’ve had a pool installed & was beginning to question my plan to use stone or bluestone around it. My son has it and complains that it is too hot on the feet at his vs. concrete so I was thinking of using one of the products described in this Months HB but am not sure about the framing below. Is it practical to frame the deck tight to grade? Here in the NE we install all decks above grade with 4′ frost footings. What happens at grade? Could I frame it with just 4″ x 6″ sleepers in 8′ x8′ squares or will it heave?
Concrete would have to be pumped in where this is and it may be my last resort.
Any suggestions will be appreciated.
    intrepidcat | Jun 16, 2005 12:36am | #1
    bump
    maybe your question just got missed and now someone who can answer it will see it this time
    I invented Coke with Lime.
  2. maverick | Jun 17, 2005 05:49pm | #2
    If you ever walked on Trex barefoot on a hot sunny day you might reconsider. I'm not sure about the other composites, you might want to investigate further
Choosing a Paintbrush
  • The New Old Colonial
