porch ceiling suggestions
| Posted in General Discussion on December 4, 2003 12:32pm
I’m looking for suggestions on a material to use for my porch ceiling.  Low maintenance, easy cleaning, and some amount of brightness/reflectivity would be ideal, since it faces some exterior windows and can provide some light to the interior.  Resistant to mildewing is also important.
Is there an affordable metal system?  Everything I’ve seen in metal is out of sight expensive.  Bead-ply and some of the plastic sheet beadboard lookalikes are other possibilities I’ve considered.  The concern with those is that the small beads would be out of scale for the size and height of the ceiling.  Does anyone have a recommendation?  Also, what about handling the transitions between sheets so they don’t look like sheets?  😉
Or how about just 1×6 t&g pine.
Ceiling height is about 8′ at the low end and 11′ at the high end.  Area is about 14’x38′.  Joists are 24″ OC.
thanks
-dumfounder
    CapnMac | Dec 04, 2003 12:45am | #1
    Could look into the new Azek beaded panels--ought to be both bright and very low maintenace.
  2. LynchPin | Dec 04, 2003 01:18am | #2
    Sounds like this a porch with a roof already? So you can't
    sheath your roof with something that is pleasant to look
    at from underneath? We always sheath porch rooves (and
    any roof eaves or overhangs where the rafters are exposed)
    with T-111, which sort of looks like beadboard. And if you're
    careful to line up the sheets, the "beads" look continuous
    across the rafters. You could still use T-111 on the underside
    of the rafters and just put some kind of batten (1"by cedar or
    something) on the seems. It's cheap, looks good painted
    or clearcoated, and it's quick to put up since it's in 4'x8'
    sheets.
    Good luck.
    John
    1. dumfounder | Dec 05, 2003 06:13am | #4
      yeah - there's a roof on there; hence the lack of urgency.  :-)
      i had considered that originally but wasn't sure how to handle the electric in the ceiling, and wanted to insulate the roof to accomodate future changes that will probably never happen...
  3. calvin | Dec 04, 2003 02:36am | #3
    If you can fathom vinyl and the run of the soffit material can be made seamless or you cover it, restoration beaded soffit from wolverine is pleasing to the eye, low (no) maintainence, and fairly reasonable considering the finish is done.  You can ledger the perimeter with wood instead of "J" and soffit comes both solid and vented (invisible).  Check it out here:  http://www.siding.com/pro/siding/wolverine/products/restbead.html
    Quittin' Time
    1. dumfounder | Dec 05, 2003 06:17am | #5
      thanks to you and CapnMac for the replies - looks like the wolverine premium double 5" soffit works with 24" spans.  I'll check into that.
      -dumfounder.
Fast, Accurate Wall Framing
