porch flooring
drozer | Posted in Construction Techniques on May 23, 2009 03:49am
i am repairing a front porch, with balcony above.
around here, all of the porch flooring was originally done in 4 x 5/4 t&g pine (or maybe spruce). that’s hard to come by now, and, anyway, they want it replaced with something pressure treated.
home depot used to carry a 6 x 5/4 v groove decking, but not anymore.
any suggestions? remember, this is a front porch and not a back deck, so plain old PT planks won’t cut it.
  1. john7g | May 23, 2009 04:00pm | #1
    try a local lumberyard and not a BigBox
    1. drozer | May 24, 2009 05:15pm | #6
      would if i could, but they've all been driven out of business.the closest "local" yard is 45? minutes away.there used to be a yard right downtown. call in the morning, (free) delivery in the afternoon.now it's condo's.
  2. Piffin | May 23, 2009 05:26pm | #2
    CVG Fir
    Tendura
    IPE`
    1. drozer | May 24, 2009 05:26pm | #7
      wasn't familiar with cvg, then yesmaam defined, so i googled.nice stuff.but this house is part of a 4 door row, and they have some sort of home owner's agreement that stipulates that the exterior has to remain the same.so that means 4 x 5/4, painted porch floor grey. i was hoping there was a PT product available, but i guess not.i can still get the 5/4 spruce, so will probably end up using that. would it be a waste of time to back prime the underside (84 ft')?
        Dam_inspector | May 24, 2009 06:19pm | #8
        <<<would it be a waste of time to back prime the underside (84 ft')?>>>NoAnd prime the sides as well.
        1. Piffin | May 25, 2009 12:33am | #10
          Absolutely. i would not dream of using T&G on a porch deck without sealer/primer all six sides before installing - esp spruce.
      2. Piffin | May 25, 2009 12:30am | #9
        You can have CVG Fir in 5/4 x 4
  3. YesMaam27577 | May 23, 2009 05:54pm | #3
    What Piffin said -- clear vertical grain fir.
    Politics is the antithesis of problem solving.
    1. Houghton123 | May 25, 2009 02:12am | #11
      back and end prime it.
  4. frammer52 | May 23, 2009 08:03pm | #4
    Tendura, but you will have a little sticker shock, in fact you will also with the fir flooring!!
  5. fingers | May 23, 2009 08:34pm | #5
    Did Tendura get bought by Correctdeck and now it's called Correctporch.
    Also Azek came out with a product very similar to Tendura but I believe it does not have to be covered like Tendura.
