poring post holes
daveytree | Posted in General Discussion on March 1, 2009 07:16am
I need to pour 3 ,12in. post holes up here in western new york trying to get the job done a.s.a.p for my friends sign for a new business tempurtures and weather is an issue of coarse, trying to get to 40 degrees at pour-time with the concrete alittle stiffer than normal is there a make-shift vibrator or some other rig to make sure concrete is solid at the bottom , holes are about 54 inchs deep,some stone at bottom and oh that 6 x 6 treated post , some sono tube going 6 inchs above ground.
  1. Piffin | Mar 01, 2009 07:25pm | #1
    makeshift vibrator - broken blade in a sawsall to pound against the post or the sonotube
    Ted W. | Mar 01, 2009 07:50pm | #2
    Stab at it with a broom stick or similar, while pouring. It's not a vibrator, per se, but it works.
    ~ Ted W ~
    Cheap Tools - BuildersTools.net
    See my work - TedsCarpentry.com
    Edited 3/1/2009 11:51 am by Ted W.
  3. Waters | Mar 01, 2009 08:40pm | #3
    If you have a rotary hammer drill, put it on "Hammer" so it doesn't spin, use a chisel bit, or a big, old drill bit and buzz away against your form.
    This works better for me than any sawzall, palm sander, or manual technique.  Brings up a rush of bubbles, right away.
  4. Sasquatch | Mar 02, 2009 01:58am | #4
    Concrete a little stiffer than normal?
    I don't get it, but even so, why not just make the first few inches "normal"?  Then pour the stiffer mix in on top and follow the advice of the other posters if you feel it will help.
    How can you understand God if you can't understand people?  How can you understand people if you can't understand yourself?
      Matt | Mar 02, 2009 03:13am | #5
      Maybe he feels it will set up quicker if it is placed stiff...
