Should the bottom and adjacent edges of a pork chop eave return be at 90 degrees to each other? The reason I ask is I’m replacing one that has some rot and when I measure it the back edge is angled backward, is not 90 degrees to the bottom edge, and is not fully in line with the corner trim board below.
Listeners write in about shower panels and cordless tools and ask questions about old wiring, air leaks, and gutter covers.
Not a commandment set in stone. Does the return not have a sibling you can match?
The return is still on he house and intact. My plan is to make a patch out of PVC which will replace the pork chop and part of the rotted rake that the pork chop abuts. (I saw this in an FHB article). The patch is laid over the area and cut around with an oscillating multi tool. I laid out the patch by taking measurements off the return area. I made the patch with a 90 degree angle on the area over the chop but when I laid it over the existing return I found that the existing chop slopped backward and was not 90 degrees. I was curious why the chop wasn't 90 degrees. Maybe because it was field cut or followed the rake angle? I thought it would look better if the back edge of the chop lined up with the vertical corner trim board that it covers.
