Portico Roof Tilt
tomde01 | Posted in Code Questions on October 5, 2020 11:18pm
I’m not sure if this is a code or not. However, after looking at several gabled portico roofs in the area, they all seem to be tiled or sloped away from the house sidewall. Most appear to be around an inch or two over 6ft. Is this intentional to prevent water from dripping back towards the house? I was planning on having a level ridge and build a small deverter near the house’s side wall. Does this seem reasonable?
Tom
  1. andy_engel | Oct 07, 2020 06:26am | #1
    It could be that the outside of those porticoes has settled over time. They are typically built with a level ridge, as you suggest.
Fast, Accurate Wall Framing
