Post size on piers foundation retrofit?
1000eyes | Posted in Construction Techniques on June 7, 2007 05:15am
Hello
I am about to retrofit/replace the crawl area framing of my 1966 post and pier with perimeter walls foundation with new piers pads and posts. Currently the piers are directly on the dirt with 4×4 posts. I plan to pour new pads and replace the posts. Is there some rule of thumb that can indicate what post size is approprate for a particular application. I have seen both 4×4 and 4×6 lumber used  but do not know what determines the size.I realize that it could be engineered to determine exact loads but was hoping for some general guide.
  1. dovetail97128 | Jun 08, 2007 05:51am | #1
    1000eyes,
    You do not have your location filled out in your profile so I am not sure this will apply.
    Here in Ore. the common practice is 4 x 4 under beams spaced 32" - 4'O.C.(beam spacing , not post spacing), Except at the joints between beam ends where a 4 x 6 is required. All posts must have plywood gussets attaching them to the beams.
    "Poor is not the person who has too little, but the person who craves more."...Seneca
