Post-toPost Connections
markledbury | Posted in Construction Techniques on August 9, 2004 10:05am
What is the best way to join two 6X6 post together vertically?  I’m building a deck whose decksurface is about 16 feet above the ground that will have a roof over part of it.  There will be two posts that will run from the ground to support the deck and the roof beams.  The largest 6X6 post I can buy is 20 feet long, but I’m going to need about 24 feet of of length.  I’m thinking about using a 16 foot and and 8 foot long post, but am unsure about the best way to connect them together.
    Sphere | Aug 09, 2004 10:16pm | #1
    a long half lap scarf joint, glued with PL premium and thru bolted. I have used PT 8x8 at 24'...special order, but we got em. A real bitch to stand up tho'.
      edit: by responding, does not mean I condone the splice practice..you asked, I responded..that's all.
    Edited 8/9/2004 3:18 pm ET by SPHERE
    1. markledbury | Aug 09, 2004 10:20pm | #2
      Thanks for the quick response!  How long is long for the half lap scarf joint?  12", 18"?
      Thanks again!!
        Sphere | Aug 09, 2004 10:29pm | #3
        using yer example...4 FEET minimum.
        1. markledbury | Aug 09, 2004 11:09pm | #5
          Thanks!
      CapnMac | Aug 10, 2004 12:54am | #8
      The boat builder in me wants to say that a hook scarf, or, even better a locking hook scarf joint would be better for making a "mast," since that is the direction he's going.  Might even look cool with contrasting wedges driven in . . .
      I'm remembering that a structural scarf is 18-24 times depth, an lipped either d/8 or 1/4" which ever is larger.
      But I'm remembering without reference before me, structural timber practice from 17th century boat & ship building, too.Occupational hazard of my occupation not being around (sorry Bubba)
        Sphere | Aug 10, 2004 12:59am | #9
        I agree..I wasn't about to explain a locking scarf..he needs another plan
  2. JohnSprung | Aug 09, 2004 10:30pm | #4
    Building permit?  Engineer's wet stamped drawings?  Both would be required to do this here.
    -- J.S.
  3. DanH | Aug 09, 2004 11:30pm | #6
    Is the roof going to be attached to the house on one side? If so, then just plaform frame the thing and X-brace the roof. No need for long posts.
    RichColumbus | Aug 10, 2004 12:50am | #7
    I personally wouldn't do it.
    Too much stress on that joint... too high up not to hurt someone when (note "when") it breaks... the issues just go on and on.
    Either special order the things, use steel and build wrap it for looks, come up with a design that doesn't require that long-a posts... but I would not recommend trying to extend a wooden post vertically.
    RichColumbus | Aug 10, 2004 01:06am | #10
    One more alternative
    Perhaps (check with an engineer) block it up and then veneer with cultured stone, brick, etc.  Might make a nice look.
  6. Sasquatch | Aug 10, 2004 02:24am | #11
    Get some Al plate, about 1/4", argon-welded, into a two-foot long, square sleeve for each post to serve as a splint.  Bolt it into both 6X6s and get a structural engineer's approval.  Even so, you are pushing the limit and taking on great liability.  At least with the Al, you will not have the same corrosion problem as with steel.  Make sure the bolts are Al too.  Far better would be to come up with a completely different solution, such as steel posts with a cedar cladding to look like 1X6s.
    Les Barrett Quality Construction
  7. MikeCallahan | Aug 10, 2004 02:41am | #12
    A scarf joint is a bad idea. Don't do it. Splice the post where it passes through the floor joists or ceiling joists. Use a simpson BC 6 connecter and block all four sides around the post at the splice. This is standard practice and no engineering is required. The post is still considered continuous if you splice it this way.
    Mike Callahan, Lake Tahoe, Ca.
  8. User avater
    Dinosaur | Aug 10, 2004 08:20am | #13
    You don't need to do it that way. And it'll look top-heavy, too.
    Much simpler to build the deck on the 6x6x16-footers, and then add on 4x4 posts to hold up the roof beam. These 4x4's sit right on the decking, toe-nailed to it. Place them directly over the 6x6's--this keeps your roof load transferring straight down--but they do not need to be attached to them. Build a structural handrailing such as a RR trestle form. This is a typical architectural detail up here, called Croix St-André in French. It will hold those 4x4 roof posts up plumb until the whole building falls down, and maybe beyond that....
    BTW, I hope you're planning to put intermediate X-bracing on those 6x6's before you get all the way up to 16 feet. Use 4x4's let into the face of each 6x6 1.5" deep, and lag bolt each joint with two 3/8x5 grade 3 or better lags and big flat washers. Squirt some structural adhesive in there too, if you want to have a belt with your suspenders....
    Dinosaur
      Sphere | Aug 10, 2004 03:12pm | #14
      Dino-dude, If he were (or anyone else) in WNC {west north carolina}..where I was..it is REQUIRED to use 5/8 all thread or long hex head bolts, for wind bracing.  Even if it's let in, lags were a no-no.
      I wound up using a hole saw to create a counter bore for the nutz and washers..then a thruhole for the all thread.
      Just FYI.
        Dinosaur | Aug 10, 2004 09:00pm | #16
        Thank you, bro. Good to know. I prefer to use through-bolts myself, but I know most DIYers don't usually have beefy enough drills to go through  big gnarly 6x6's without toasting the motor....
        Trick I use to counterbore the bolt-heads and washers is to drill about ½-¾" deep (or deeper as necessary) with either a spade bit or a Forstner or saw-tooth (depending on size), then drill through the rest with a power auger. As I get near the other side, I slow down until the pilot screw just peeks out, then I back it out and counterbore from the other side using the pilot screw's hole as a target.
        Dinosaur
          Sphere | Aug 10, 2004 09:11pm | #17
          yeah man, same here with the pilot on the auger. When I made them log stairs my counterbores were so deep, I had to have a solid pilot made that fit my 1 1/2'' saw tooth type borer...it would then follow a 1/2'' through hole..just screws in place of the threaded pilot. An using allthread couplers for nuts I had to weld a reg. socket to a deep socket to have enough room for the bolt ends..sheesh, too much engineering.
          I could just see a DIY using a 1/4'' crapsman drill with a 18'' long 3/4'' auger..lol...no, wouldn't work..need a 3/8'' chuck for that..
          I gotta gain some weight, my 1/2'' RT angle keeps lifting me up..mebbe lead bars in the tool belt?
          1. mikerooney | Aug 10, 2004 09:45pm | #18
            Sash weights. :}
            Sphere | Aug 10, 2004 11:49pm | #19
            good plan...I got some somewhere.
            Dinosaur | Aug 11, 2004 05:41am | #21
            For stuff like that a boring bar is easier once you get the pilot hole drilled. Just run it through, set in the right size cutter, and turn the crank. It'll pull it's way right through dead effin' straight. This is how the 2,3,4, or 10'-long holes for keel bolts are put into boats....Dinosaur
  9. Piffin | Aug 10, 2004 08:25pm | #15
    I don't like the half lapps and there is no need for it. Build the deck on the base posts, then start off again from the deck up to build the roof.
    Check out the thread here parralell to yours about the deck collapse to keep yourself grounded. The deck should be let into the posts or built on top of them.
    Think twice about each joint, analysing how can this go wrong, and don't assume anything.
  10. Shavey | Aug 11, 2004 02:42am | #20
    Talk with a welder to see if he can make a 4ft sleeve to fit around the 6x6posts with a dead stop in the center of it. Then have him make holes for thru bolts, after its bolted together trim out your posts with azek to hide the steel sleeve make sure it has a heavy coat of paint on it tho ( just an option to consider ok!!)
  11. PecosBill | Aug 16, 2004 06:09am | #22
    How about using square steel tube?  6 x 6, 5 x 5 or 4 x 4 could be used depending on exactly what size you thought looked nice.  Extremely strong.
  12. jayzog | Aug 16, 2004 02:23pm | #23
    You can get pt gluelam posts long as you need em. Barn builders use them all the time.
    1. Richie921 | Aug 16, 2004 04:15pm | #24
      I wouldn't splice a bearing post.  Better to use one piece of engineered lumber.  If not I agree with the poster who said to use steel columns and case them in wood.  Much stronger and safer.
