Pot lights and insulation
Diomedes | Posted in Energy, Heating & Insulation on May 5, 2009 04:31am
My folks just bought a bungalow and the previous owner has run pot lights in the kitchen ceiling. After searching for access to the attic (there wasn’t) I punched a hole in the linen closet and crawled up there. The pot lights have about a three inch gap from all the loose fill insulation (it looks like the previous owner just swept the insulation away from the lights). My question is; should I build a box out of some spare rigid insulation around the lights and then cover it with some batting. Or should I remove them and install the proper IC (insulated ceiling) rated boxes and then re-install…
Open for suggestions
  1. JTC1 | May 05, 2009 04:45am | #1
    IC = insulation contact.
    At least it sounds like the previous owner properly installed the can lights which he had. 3" is the specified clearance to insulation for most non-IC cans.
    Toronto??  I would be inclined to buy cans that were ICAT - insulation contact, air tight.  Install per manufacturer's recommendations, fill any gaps around the perimeter of the can with the fire barrier caulk, install the gaskets provided and then bury them in insulation.
    Air tight = no openings through the can to produce heat loss, will be listed / identified as such. Heat loss can be significant through all those little holes.
    Jim
  2. Clewless1 | May 05, 2009 03:40pm | #2
    I'd say either way will work. Build the box out of rigid insul., GWB, or plywood.
    The other posters suggestion to install ICAT is a good idea if you are going that direction.
  3. brucet9 | May 05, 2009 10:29pm | #3
    Your thread title misled me. I thought it was going to be a question about installing grow lights for a cash crop. :)
    BruceT
A New Approach to Foundations
