Pot /Recessed lights in ceiling panels
doug07 | Posted in General Discussion on January 11, 2008 11:24am
Hello,
I am installing a suspended ceiling (2′ X 4″ panels) in my basement and want to install some pot/recessed lights.
Are there any tricks and is there a special type of light I should buy?
I would imagine the panel itself cannot support the weight of the light, so I would imagine they’re mounted to the upper floor structure.
I would appreciate any info or links that would help me with this project.
Thanks in advance,
  1. rez | Jan 18, 2008 09:58pm | #1
    Greetings doug,
     As a first time poster Welcome to Breaktime.
    This post, in response to your question, will bump the thread through the 'recent discussion' listing again which will increase it's viewing.
    Perhaps it will catch someone's attention that can help you with advice.
    Cheers
    Peace in.
  2. danz857 | Jan 18, 2008 10:34pm | #2
    Hello,
    I believe most of the "new work" can lights with the purchase of some additional hardware can be mounted to the ceiling track. I am sure someone will correct me if I am wrong.
    Dan
  3. Richie921 | Jan 18, 2008 10:42pm | #3
    Doug,
    Dan's right, they get mounted to the framework for your drop ceiling.
    maddog3 | Jan 18, 2008 10:47pm | #4
    I use 1/2 EMT as brackets and some tie wire..but some mfrs. supply brackets in the form of C channel, that would work too
    orient the brackets so the supports lay on the mains. and try to keep the fixture close to the tees and avoid the urge toput them centerd on the 4' side.too much sag
    draw lines on the diagonals and find your centers. it's easier
    in the old days we would cut 1/4 plywood to match the grid openng and lay it on top if the tile.
    some of the old Hi-hats were pretty heavy
    , wer ist jetzt der Idiot ?
    1. doug07 | Jan 19, 2008 01:17am | #5
      Thanks very much for all the info, I will look at these options.
      Thanks,
How Trump's “Big Beautiful Bill” Will Affect the Inflation Reduction Act
The Big Beautiful Bill could do away with much of the Inflation Reduction Act, including the 25C, 25D and 45L tax credits.
  • A Postwar Comeback
