Poured foundation holes
rmort | Posted in General Discussion on February 28, 2008 06:51am
Hello
I am here to ask for some advice and help. We are looking into finishing a basement. The poured concrete foundation has regular holes in it – I assume from the forms. When a remodeler was looking at it he appeared horrified that these were not filled and said that they go all the way through the foundation to the soil outside. He also seemed amazed that they did not leak. There has never been any leakage from these holes even in very heavy rain. When giving us a bid it did not include filling these holes since he said he hadn’t counted them.
Could anyone tell me
What are these holes from and is it likely that these holes do go all the way through?
Do they need to be filled?
If so with what and what is a reasonable cost?
any help would be very much appreciated- rmort
  1. cardiaceagle | Feb 28, 2008 06:55pm | #1
    filled/patched on the soil side of the concrete...
    1. rmort | Feb 28, 2008 08:00pm | #3
      Since they have not leaked, I presume you are correct that they are filled on the soil side. If so is there any reason to completely fill the form tie holes? I do not have any pictures at the moment but they fit the description of form tie holes (5/8" there are 3 per form section).
      rmort
      1. cardiaceagle | Feb 29, 2008 02:47am | #4
        no reason...imho
        regards
    BossHog | Feb 28, 2008 06:59pm | #2
    They're probably just left over from the form ties.
    Any chance we could get some pics of them?
    Tell a man there are 400 billion stars and he'll believe you;
    Tell him a bench has wet paint and he has to touch it.
  3. MikeSmith | Feb 29, 2008 05:27am | #5
    they sound like form tie  holes.... they are usually snapped off  1/2" below the surface of the concrete in and out
    then outside they patch the hole and backfill
    sometimes people get confused and instead of snapping the ties , they work them all the way out
    anyone who goes to this extreme has probably also patched them on the outside
    if they haven't leaked by now , they will probably not leak
  4. mike4244 | Feb 29, 2008 06:46am | #6
    The holes are from form ties. If they do not leak then they were filled from the outside.Most form ties are not removed except for a small portion near the wall face. The contractor may have used taper ties,unusual for residential work. These ties are greased and meant ot be pulled thru after the wall has set up,next day usually.
    The inside of the walls probably do not need anything. If you want,get a small bucket of hydraulic cement and a small trowel. Mix according to directions, push into the hole with a trowel and smooth over.This type of cement expands and is water resistant,maybe waterproof,not sure.Depending on the cement you have a limited time of use.Mix small batches at first  so you can determine how much to mix beforethe mix sets up.You can do this yourself and save a bit of labor .
    mike
    popawheelie | Feb 29, 2008 07:36am | #7
    I can't believe he didn't know what they were and that he appeared horrified.
    1. rmort | Feb 29, 2008 03:32pm | #8
      thank you all for your responses
    2. Piffin | Feb 29, 2008 04:18pm | #9
      he probably takes the plastic film strips off the asphalt shingles too
      1. MikeSmith | Feb 29, 2008 04:26pm | #10
        hey, you're back !
        the lot  all around our first house was littered with those pesky plastic strips
         i was so relieved when someone told me i didn't have to peel them offMike Smith Rhode Island : Design / Build / Repair / Restore
        IMERC | Feb 29, 2008 04:27pm | #11
        welcome back...
        I hope as is reasonably well or at least as well as can be...
        1. Piffin | Feb 29, 2008 07:59pm | #12
          actually, I am in Florida riught now. I was home for about ten days, then came back down last friday.
          Guess I'll have to strt another thread later to explain it all. limited time online right now
        Matt | Mar 02, 2008 03:55am | #13
        >> he probably takes the plastic film strips off the asphalt shingles too <<
        Did you read the other thread about keep-aholics?  I have trash bags full of those plastic strips.  I wonder if they have any resale value ;-)
        1. Piffin | Mar 02, 2008 09:56pm | #14
          don't get me started
          1. brownbagg | Mar 03, 2008 12:29am | #15
            even if they are not patch, they are not going to leak till the wire rusted out which could be fifty years. you can patch the inside and forget about it.
