Is a block foundation for a crawl space as good as a poured foundation for a small room addition with a shady northern exposure in a mid-atlantic climate? We are concerned that it be absolutely dry.
![](https://images.finehomebuilding.com/app/uploads/2024/08/07145339/FHB-Pod-Ep-644-Feature-thumb-16x9.jpg)
Listeners write in about changing careers and organizing volunteer builders and ask questions about high humidity, underfloor cooling, and removing ceiling texture.
In my parts, poured concrete foundations are not cost effective for crawl spaces. A block crawl will be dry with a proper drain system and damp proofing. Recommendations for basements are a different story.
*dry is not a function of wether it is poured concrete or block.. it is a function of :good drainageexterior waterproofingvapor barrierunderdrainssmp pumps or drains to daylightafter i make sure the basement is going to be dry , i also make sure it is going to be comfortable.we install 2" styro -SM (R-10) under the slab,but knowing what i know now , i wud probably use 3" EPS "Performguard" ..and then stud the walls..
