Pouring Concrete Wall
fxdp | Posted in Construction Techniques on September 10, 2009 12:52pm
I’m pouring a new foundation/basement wall under my house. Since it goes all the way up to the joists, there’s no way to rod it as it’s poured to eliminate voids.
I’m sure someone knows a technique to improve results in such situations, which I hope you’ll share. What’s the best way to deal with such a pour to minimize voids?
Thanks.
  1. inD47 | Sep 10, 2009 12:59am | #1
    it needs to be vibrated, remember fast in, slow out.
    if there is access for a hose to pump in concrete there is access for a vibrator.
    1. brownbagg | Sep 10, 2009 04:00am | #2
      rent a concrete vibrator
  2. 6bag | Sep 10, 2009 05:09am | #3
    you can add super plastisizer to the mix, this will make the concrete wet for about an hour and after it wears off the concrete will set as if it were never in there.  this will not effect the strength of the concrete.  this will ease the placment of the mix.  be careful, wet concrete = more preasure on forms.  if you use a plastisizer, don't let readi mix add it at the plant.  it sould be added at the time of placment.  you get a small window of time to work with the suff, when its done it's done.  adding water once the plastisizer has worn off is a big no no.  another option is to use a smaller aggergate in the mix.  1/2" stone with some extra sand will help with honey comb.  becareful not to over vibrate, you may end up with bug holes.
      Jeff_Clarke | Sep 10, 2009 08:04am | #8
      Interesting point, since I've been looking all day for a point-of-use SuperP that comes in something smaller than a 55 gallon drum (!)
      The concrete countertop supply people have it:http://www.concretecountertopsupply.com/store/ccp0-catshow/AdmixturesPozzolans.html
      SteveInCleveland | Sep 11, 2009 08:08pm | #16
      That's some excellent advice.
      "Preach the Gospel at all times; if necessary, use words."  - St. Francis of Assisi
      No, I didn't vote for him; but he IS my president.  I pray for the his safety, and the safety of his family every day.  And I pray that he makes wise decisions.
  3. Jay20 | Sep 10, 2009 05:36am | #4
    If the issue is access through the top of the forms to get the vibrator in look at vibrators that attach to the exterior of the forms.  It will cost more than renting a normal vibrator since they need to be attached before the pour and can't be moved but in some cases that's all you can do.
    1. inD47 | Sep 10, 2009 05:56am | #5
      If you can't get the vibrator in how will you get the concrete in is what I want to know.
      1. Jay20 | Sep 10, 2009 06:31am | #6
        Some pours have limited access. The vibrators that are affixed to the forms besides consolidating the pour are used to move the material to areas not accessible.
  4. whitedogstr8leg | Sep 10, 2009 07:49am | #7
     First off, how high is the forms we are talking about?   If it is under 3', then use your hammer on the outside of the forms as a "vibrator".   Just "whale the hell out of 'em",   , and be sure you do it equally to all the forms.   One other "trick" you might try,  use a "palm sander" held against the outside of the forms.   As for the concrete itself,  use a #6 or high slump to let the concrete "flow" into the forms.   Hope this helps out.
    " Although I have the right to remain stupid, I try not to abuse that right"
      SamT | Sep 10, 2009 03:50pm | #9
      That reminded me: Have used SawZalls w/o blades as outside vibrators.SamTA Pragmatic Classical Liberal, aka Libertarian.
      I'm always right! Except when I'm not.
      1. mike4244 | Sep 11, 2009 01:04am | #11
        I have a palm nailer with an attachment for vibrating the outside of a form. If i recall just a metal block that replaces the barrel. Used it one time on small pedestals under a crawl space.
        mike
    2. fingersandtoes | Sep 10, 2009 10:01pm | #10
      Yeah, for short walls I never use a vibrator. Someone with a bit of experience and an estwing means no honeycombing. Young, enthusiastic kid doing the same usually means wrecked forms though.
        Jeff_Clarke | Sep 11, 2009 01:51pm | #12
        A rubber hammer is less likely to bust things up.
        1. brownbagg | Sep 11, 2009 02:58pm | #13
          Just rent a vibrator it like $25 a day. Even Home Depot has them
        2. fingersandtoes | Sep 11, 2009 06:22pm | #14
          "A rubber hammer is less likely to bust things up."
          I form all short walls out of 1"x8"s. It's easy to see when you have bashed them enough as they begin to seep through the cracks. A rubber hammer is a good idea, although I'm not sure what the rest of the guys might think...
          1. whitedogstr8leg | Sep 11, 2009 06:34pm | #15
             When using a hammer as a vibrator, don't hit the forms like you were trying to drive a spike.    Half-swings, and get a nice, steady tapping going.    You can tell by the sound of the forms being hit, how well you are doing.   A rubber hammer would be an idea, but the mallet wouldn't last very long.   Just start "tapping" at the bottom of the form, work a circle pattern up towards the top of the pour. " Although I have the right to remain stupid, I try not to abuse that right"
          IMERC | Sep 12, 2009 12:36am | #17
          you never met some of the helpers out there...
          WOW!!! What a Ride!
            Jeff_Clarke | Sep 12, 2009 12:56am | #18
            Actually I have ;o) (seriously)
          2. whitedogstr8leg | Sep 17, 2009 09:30am | #19
             Helper?  That looks like one of my old foremans!   Usually just to scare the "new-to-this-kind-of-work people." Although I have the right to remain stupid, I try not to abuse that right"
          3. brownbagg | Sep 17, 2009 04:17pm | #20
            I mention earlier about using a vibrator in pouring a wall, As a rental, vibrator are cheap, about $25. Everybody here keep saying, oh just hit it with a hammer. well that is fine but a hammer does nothing to remove air pocket interior of the wall. These air pockets are a structual issue with freeze cycle.
          4. whitedogstr8leg | Sep 17, 2009 07:14pm | #21
             With the type of wall the OP was talking about ( short, narrow) a hammer will be just fine.   Anything under 8" wide and 36" tall will hammer-vibrate just fine.   Now, IF the was a LOT of "stuff" in the wall pour (too much rebar, pipes, conduits, and the like) then a regular vibrator is needed.   Also, with the "hammer-vibrator", there is less chance of over vibrating and cause a blow-out.    Vibrators tend to "loosen up forms as well as concrete.     In a wall the size the OP wants, use a 7-8" slump concrete and the hammer.   Pour it thin and let it flow. " Although I have the right to remain stupid, I try not to abuse that right"
          5. ncproperties | Sep 18, 2009 04:10am | #22
            Hilti TE-75 with a bush head. Have used it many times in no access pours. In these tight pours where blow out from vibration are balanced with heavy need for vibration, we'll often start to pop relief holes in the bottoms of the form ply. Most times just a couple 16's pounded and pulled to just let the juice out.
          6. brownbagg | Sep 18, 2009 04:53am | #23
            I<M NOT TALKING ABOUT HONEYCOMB but the entrained air and entrapped air of wall placement
          7. whitedogstr8leg | Sep 18, 2009 07:47am | #24
            SIGH" Although I have the right to remain stupid, I try not to abuse that right"
FHB Podcast Segment: Roofing on Commercial vs. Residential Buildings
In certain scenarios, flat roofs make more sense than pitched roofs (and vice versa).
  • A Postwar Comeback
