Any problems with pouring a garage floor(unheated building) when the tempature may “just” hit freezing? Will a six inch pour have a better chance of curing in cold weather than a four inch pour? What is the lowest reasonable “overnight” temp a floor can be pour without additives or special care? How much longer does it take to cure at lower fall temps – 40 to 50 degrees? My manual does not have pratical info it talks about covering the pour with 6 inchs of hay.
![](https://images.finehomebuilding.com/app/uploads/2024/07/17093454/01232564-sited-in-the-trees-thumb-16x9.jpg)
This home features dramatic interior spaces enhanced by views of the surrounding trees and stream.
Any problems with pouring a garage floor(unheated building) when the tempature may "just" hit freezing? Will a six inch pour have a better chance of curing in cold weather than a four inch pour? What is the lowest reasonable "overnight" temp a floor can be pour without additives or special care? How much longer does it take to cure at lower fall temps - 40 to 50 degrees? My manual does not have pratical info it talks about covering the pour with 6 inchs of hay.
