Powder room clearance
ceb | Posted in General Discussion on December 31, 2006 01:57am
Need to relocate a powder room into a narrow space — about 7 feet long and only 40 inches wide. Entrance door is on one of the 40″ walls. Toilet will go at one end of the room directly across from the door.  Is there a minimum clearance past a sink? I can probably find a sink about 14″ deep, leaving about 26″ of clearance past it. Recognizing that codes vary nationwide, is this typically a problem? Thanks.
Carlos
    McDesign | Dec 31, 2006 02:18am | #1
    Seriously consider the tank top replacement with a lav built-in.
    Meets code and is coolness itself.  Incoming tank fill water automatically comes out of the faucet; drains into the tank.
  2. Piffin | Dec 31, 2006 03:07am | #2
    Toilet in a powder room
    Why not put it in the head? Be easier to keep the powder dry that way.
      Heck | Dec 31, 2006 03:10am | #3
      You're not immune either, are you? <g>_______________________________________________________________
      my tagline fell down, and can't get up
      1. Piffin | Dec 31, 2006 03:39am | #4
        not totally sober either
          Heck | Dec 31, 2006 04:42am | #5
          Aha!
          Well, I'm headed that way myself, soon as I digest the bbq ribs and corn on the cob and several glasses of sweet tea, and ....zzzzzzzzzzzzz_______________________________________________________________
          'what if there isn't a tomorrow? there wasn't one today' - Phil Connors
  3. CAGIV | Dec 31, 2006 07:00am | #6
    The uniform plumbing code requires a minimun of 24" in front of stool for clearence.
    That is one rule I know well.
    Team Logo
  4. ponytl | Dec 31, 2006 07:41am | #7
    i have seen in some very tight spaces... some very small sinks... think stainless and an RV or boat... you can also if you get lucky set the sink back between studs and gain about 2.5 inches...  i've also seen a 10" wide  sink that was about 24" long and wall mounted....  you actually have alot of room for a small powder room... now you have to figure a way for it to "feel" larger...
    p
Drafting the 2027 IRC
  • The New Old Colonial
