I’m replacing the window jambs and casing on my 23 year old house. It looks like the original jambs were pre-fabbed offsite and then popped into the rough opening with clips that were installed into the jambs.
The jambs were rabbeted and had the clips pre-stapled in the rabbet, and then the assembly ‘clipped’ into the window.
Is this pre-fab assembly something I can purchase? I can’t really see who the window manufacturer was.
Pictures of assembly: https://imgur.com/a/e5wh8j1
I don't know what your clips look like but it's pretty straight forward to build your own preassembled trim jambs some times even with the trim already installed. Even if you could find them factory built they would likely be pricey and with limited style options.
