Hi all,
Has anyone ever busted up a set of concrete precast steps. These are in very good condition but are sinking and cust thinks they are ugly. Got to go. Any tips on best way to remove with be helpful.
Hi all,
sledge hammer and a 19 yo. should be no problem,they are hollow on the inside.
easier way would be to throw a ad on cl for 10.00they load and haul.larry
if a man speaks in the forest,and there's not a woman to hear him,is he still wrong?
Wonder how much something like that could weigh?
i'd call a local lumber yard that sells them and ask what they will weigh,must not be so much you can't get them into place when installing new ones.if a man speaks in the forest,and there's not a woman to hear him,is he still wrong?
Thanks for all of your replys. I took a 10lb hammer to the steps. They broke up real nice. Some rebar inside but it was only 1/4" thick. Bolt cutter took care of that. The concrete was easy to bust up. Cust wanted broke pieces for fill. It could not have worked out better (unnless I had that 19yo along to do the work). Thanks again!!
Here's a link to thread where it was discussed before:
http://forums.taunton.com/tp-breaktime/messages?msg=108598.1
I had 3 steps about 3' wide in my garage, part concrete block (some of which were filled) and part cast concrete. I used a demolition hammer and it still took about 2 hours. They weighed about 1,000 lbs. I know that because I took them to the local transfer station where they weigh you in and weigh you out. In all, I dropped off about 1,200 lbs, but there was other stuff mixed in.
Don't forget about disposal costs when bidding a job like this, but if you're building over/around them, you won't need to remove all of it.
When I replaced my front stoop (also 3 steps with a 3' X 5' landing) several years ago, I just used a sledge hammer because they were shoddily made and falling apart. There was no real footing. I don't remember for sure, but it probably took me a couple of days. The mason I brought in to rebuild it (after I poured a new footing) was able to bring at least 3,000 lbs (including part of the front walkway) to the concrete yard where they can re-use this material. That only cost $50.
Could put an ad in the paper for free steps in good condition.
