Preliminary Kitchen/Bath Design Question
bk73 | Posted in General Discussion on November 30, 2007 05:04am
I am starting to think about my next project at home and had some questions. I am going to be redoing the kitchen and upstairs bathrooms in our house. One of the problems I will be encountering is that when we do the kitchen I will be eliminating the room adjacent to the kitchen to make the kitchen bigger. The current interior shared wall between these rooms has the plumbing in it to go to the upstairs bathrooms.
With that wall removed I have to move all of the plumbing to the outside wall, which is currently a 2×4 wall. My neighbor with the same house just did this and kept the 2×4 outside wall. I am just a DIY’r, but shouldn’t the outside wall be made 2×6 to accomodate the plumbing pipes and extra insulation to keep the pipes from freezing? (I am in Long Island, NY.)
Thanks.
Brad
  1. JohnFinn | Nov 30, 2007 05:16pm | #1
    Good idea to. Make it as thick as possible.
    1. bk73 | Nov 30, 2007 05:39pm | #2
      Is it OK to rip a 2x4 down to 2" and screw it to the existing stud to make it a 2x6 wall?
      1. JohnFinn | Nov 30, 2007 07:53pm | #7
        That's one way to do it. Depending on how much room you have to give up you could also build an entirely new wall inside of the existing. If you can't 6" is better than 4". You are probably thinking of 6" R-19 batts for your new 6" wall?
      2. Jim_Allen | Dec 01, 2007 03:47pm | #11
        If you decide to thicken your existing wall, your idea of adding 2x2's is acceptable and routinely done without incident. If you don't mind losing a couple more inches, it probably would be better to just run another interior wall inside the old outside wall leaving the insulation and drywall intact. The chase idea often works. Decorative soffits can add interest to a ceiling while hiding dropped plumbing runs. FKA Blue (eyeddevil)
  2. peteshlagor | Nov 30, 2007 05:44pm | #3
    Is the existing wall structual?  Meaning, does it hold a weight from above and transfer that load to a supportive structure below?
  3. bk73 | Nov 30, 2007 05:59pm | #4
    Yes, the exterior wall that I will be making a 2x6 wall is a structural outside wall on the back of the house.
    1. peteshlagor | Nov 30, 2007 06:08pm | #5
      The one you wanna take out.  Is that a structural wall?
  4. bk73 | Nov 30, 2007 06:20pm | #6
    The wall that's being removed is not structural.
    JeffBuck | Dec 01, 2007 03:56am | #8
    before U tear anything apart would be a good time to call in the plumber and see what he'd need and where.
    2 story house on LI ... I'm guessing there's a drain stack in that existing wet wall, running from the basement and sevring the upper floor as well?
        Buck Construction
     Artistry In Carpentry
         Pittsburgh Pa
    1. calvin | Dec 01, 2007 05:17am | #9
      Jeff is right.  Contact a (the) plumber and find out what he(you) need to get down between the floors.  Insulate any of the plumbing FROM the outside.  Leave out any insulation to the inside (heated) of the house.  Still a #### shoot if you cannot block any and all air leaks into that stud cavity.  And that includes coming in from below-you leave a gap there and one at the top of the wall and you can generate a pretty hellacious wind tunnel.
      edit:  Don't forget, you can box in that plumbing chase-don't necessarily have to fur the whole wall out.
      http://www.quittintime.com/
      Edited 11/30/2007 9:19 pm ET by calvin
      1. RSager_em | Dec 01, 2007 08:13am | #10
        I'm with Calvin, in terms of design, a soffit (is that what you call them if they're running up a wall?) or even a pillar (if you keep plumbing in the middle of the wall where it is) can be an opportunity for some architectural detail. give some thought to exactly how your new kitchen will be most functionally laid out, decide things like if you want a walk in pantry. If you think through the whole design, maybe you will decided you do not have to move your plumbing all that far.(What I mean about the pantry is that perhaps your existing plumbing will happen to conveniently run up to the side of a door that will lead to your new pantry?)
        Edited 12/2/2007 10:50 pm ET by Dr. Becks
