Prepping Galv. Duct for Paint
chefwong | Posted in General Discussion on August 13, 2006 12:28pm
Just curious…
I was originally planning to prep my galv duct for paint using Zinssers 123 primer…
My duct guy told me a better way of prepping it for paint would be vinegar. Wipe the duct down with that and it removes the galv coating.
Just sharing my findings.
  1. ponytl | Aug 13, 2006 01:29am | #1
    vinegar is all the gutter guys use before painting galv gutter...
    p
    IMERC | Aug 13, 2006 02:11am | #2
    make that white vinegar..
    WOW!!! What a Ride!
      MarkH | Aug 13, 2006 04:34am | #3
      How come they call it white when it's clear?  This world makes no sense.
        IMERC | Aug 13, 2006 04:39am | #4
        same reason they call that parking lot (LIE) that runs the length of Long Island an expressway...
        Edited 8/12/2006 9:45 pm by IMERC
  3. Dave45 | Aug 13, 2006 06:46am | #5
    I usually wash galvanized parts in a TSP solution, spray a Rustoleum primer, then paint.  TSP is cheaper than vinegar, too - lol.
  4. renosteinke | Aug 13, 2006 10:27pm | #6
    You want to accomplish two things; to remove any oil left from the manufacture, and to roughen the coating so the paint has something to grab.
    Vinegar, being a weak acid, does both.
    james | Aug 13, 2006 10:47pm | #7
    phsphoric acid, it is the main ingrediant in many properitary metal etch compounds.... jasco metal etch is good for this, it will remove light oil, remove surface rust and etch the zink all things leading to a good paint job.
    james
      MarkH | Aug 13, 2006 10:51pm | #8
      I used galva-prep in my car painting days.  It does have to be rinsed very well after etching.
  6. Mooney | Aug 14, 2006 02:48am | #9
    yup
    1. CAGIV | Aug 14, 2006 05:22am | #10
      what happens if you prime & paint galv metal with out using vinegar or tsp?
        IMERC | Aug 14, 2006 05:25am | #11
        peels and blisters...
        1. CAGIV | Aug 14, 2006 05:30am | #13
          next question...
          why?
          what reacts with the paint?
            IMERC | Aug 14, 2006 05:37am | #14
            alligators too...
            galvanic salts, oil / lube residue from the manufacturing process...
          2. CAGIV | Aug 14, 2006 05:39am | #15
            didn't know that.
            don't think I've painted any glav. metal recently but filed away none the less.
            I would have assumed sanding would have been enough.
            IMERC | Aug 14, 2006 05:42am | #17
            sanding is a very poor choice of prep method... it won't clean anything.. it'll still leave the salts and oil behind..
          4. CAGIV | Aug 14, 2006 05:44am | #19
            this is why I work with wood...
            not so smarts when it comes to metal
            IMERC | Aug 14, 2006 06:07am | #20
            you'll catch on...
          6. notascrename | Aug 14, 2006 05:41am | #16
            You can put vinegar on fresh galv. all day and watch it bead-up and run off. Got to break up the oil film ( not always easy). If you haven't bought the ducts yet ask about "paint grip". This is galv that has been cleaned and etched to hold paint. Hot soapy water, a good rinse,good primer will be a good start otherwise. Jim Devier
          7. User avater
            IMERC | Aug 14, 2006 05:43am | #18
            would that be Paint Loc???
          8. notascrename | Aug 14, 2006 02:00pm | #22
            MIght be, what I see is a dull, darker finish that shiny galv. Needs no prep, prime and paint does it. Jim Devier
          9. User avater
            BruceT999 | Aug 14, 2006 06:17am | #21
            Nothing is reacting with the paint to cause peeling and blistering. Paint simply won't stick to untreated galvanized surfaces, so with thermal expansion/contraction the paint and metal separate.Mild acid etches the surface to provide "tooth" so the paint can adhere.Sanding is an awful idea because; a. you can't scratch every part of the surface and b. where the sandpaper does contact it is likely to scratch clear through the zinc, leaving the steel vulnerable to rusting.BruceT
      2. Mooney | Aug 14, 2006 05:29am | #12
        What Marty said .
  • A Postwar Comeback
