The last time I prepped new galvanized gutters, I wiped them down with white vinegar. After they dried I painted. Later they still flaked some. Maybe I should’ve rinsed them after the vinegar wash?
I would wash them with a detergent first to get any oils off of them. Then etch them with something like the vinegar to give them some bite. I would rinse them off.
I haven't done this myself but have heard that some use diluted muriatic acid (HCL). Maybe vinegar isn't acidic enough to etch the galvanized surface enough. Sorry, I don't know how dilute to make the muriatic though - too strong and I guess you might strip it all off!
Yeah, muriatic is a bad choice. Use vinegar and rinse well or use a product like Galvaprep ( I haven't done any galv. gutters in years, so I haven't bought any lately, but paint stores sold it).http://grantlogan.net/
I was born in a crossfire hurricane..........shooby dooby do
I had galv gutters made for my house. Scrubbed them with vinegar and then primed with a special galv primer. I had to search for it, and it was not an ordinary housepaint primer. The paint has held up extremely well.
"Scrubbed" them with vinegar
Scrubbed may be the key word to success.. http://grantlogan.net/
There is some resistance as the scrubber moves over the oily areas, and then it's easier as you go back over an area with no oil. Learning curve = 5 seconds.
I assume you mean a 'scotch pad' type scrubber.
Correct, stolen from the wife.
I have worked with paints in another life, including painting galvanized. There are several problems with painting galvanized, all correctable.
1. NEVER use oil paints. The resin in oil paints will slowly react with the zinc in the galvanizing to form a compound that does not adhere to the metal. This is why you see paint flaking from indoor piping.
2. There are residual coatings on the galvanizing. It might be oil, or it might be the material that they put in the zinc bath to help keep dross down. In either case, scrubbing with vinegar will certainly help. It will also etch the surface on a microscopic level.
3. Fresh galvanizing is really smooth, and paint does not like smooth surfaces. Mechanical abrading really doesn't change the "tooth" of the metal as the grooves are really huge compared with the molecules of paint. But it does remove surface junk. See #2.
The best way to paint galvanized is to use a primer specifically designed to stick to galvanized. My experience has been extremely good this way. They only thing that I insisted was that the production people wash the surface. My Mantra: "The paint sticks perfectly well to the dirt. Unfortunately the dirt does not stick to the substrate".
I use to work in the metal furnishing industry. Galvanized steel is just zinc plated steel. The rub comes in in a number of areas. To cheaply extend the salt spray time ( so they can claim good rust prevention results) they add an oil coating. This doubles their results. This oil coating must be removed. The next is that zinc oxidizes easily. This and it is low on the galvanic scale is why it is used and is effective. Also zinc plating is very smooth. After removing the oil use a Scotch Pad as was suggested earlier. This will remove some of the oxide and scratch (give it tooth) the surface. Then use a metal primer preferably one for galvanized steel. Do the above the finish will last a long time and look great. Properly painted galvanized steel will last many years. Jay
Thanks everyone for the advice. I'm going to vinegar scrub, rinse, and then prime with a galv primer. Now if the rain would stop...
