pressure treated and concrete
jimk1287 | Posted in Construction Techniques on February 20, 2009 03:55am
hey i formed a pad with pressure treated lumber…poured the concrete and i want to leave the forms in and run decking on the top now(the wife)…..so my questiosn are is it ok to leave the forms in and can i put my decking right on top of the concrete with some fastners and glue….also what should i do for water running through the deckboards onto the pad…..it is pitched but will it sit there and rot the boards???
  1. frammer52 | Feb 20, 2009 04:21am | #1
    Why did you use PT wood if you thought there might be a problem?  By the way, PT is fine.
    1. jimk1287 | Feb 20, 2009 05:05am | #3
      the original plan was to form it then leave it as concrete...then  my wife decided she liked the look of decking on it...then stained...lol...thanks anyway for your help guys....what about putting decking on top of a pad...any problems wth rot there??i
      1. frammer52 | Feb 20, 2009 05:13am | #4
        pt, nope.
        dieselpig | Feb 20, 2009 05:14am | #5
        You're going to want to create a way for that pad to drain or the decking will warp, cup, and eventually rot.  PT sleepers run parallel with the pitch of the slab is SOP.  Use PL premium and a few tapcons to secure them to the slab.  Then install your decking on the sleepers.  You can run a band of PVC trim or ripped decking around the edge to hide the sleepers... but leave a gap for the pad to drain out.View Image
  2. mguizzo | Feb 20, 2009 04:33am | #2
    I used pressure treated to form up my patio pad into a sort of checkered design about 12 years ago.  No problem with rotting so far.
    What we gain in grip, we lose in touch.  R. Kipling
  3. BilljustBill | Feb 20, 2009 05:41am | #6
    If you place Pressure Treated lumber on the concrete, the sun, the heat, and weather will surely age your decking...  Why not do some acid staining in the form that looks like decking boards?
      It would drain well and easily swept or washed with a garden hose.  It should be cheaper, too.
    Bill
  4. Piffin | Feb 20, 2009 07:02am | #7
    Just say, "yes dear, what ever you want"
    The rest is inconsequential.
    wow, I spelled that right
    1. KFC | Feb 20, 2009 07:19am | #8
      Best advice ever.
      k
Picture-Perfect Pergola
