would priming the back of drywall with Bin 123 provide equal mold resistance
to green board and the substitutes. This would only be done on very small jobs obviously.
Construct the intersecting gable on the main roof for a faster, easier-to-build assembly.
Cant give you a positive answer but it almost sounds like you'd be getting into a double vapor barrier situation.
Not to mention a pain in the rear.
pain in the rear allright...
take off the trim, siding, sheathing insulation...
then put it all back up...
man that's alot of bother....
I found my Pants....
Snort!
J. D. ReynoldsHome Improvements
Why not use DenseArmour Plus or similar?
If there's moisture behind the wall, that needs to be addressed. Seems like backpriming the drywall is just a bandaid.
I don't think it would accomplish much. If you painted the back with a fungicide that might help a little.
thanks all.
