Prime it all, or spot prime?
dockelly | Posted in General Discussion on September 23, 2009 12:29pm
On most of the house I’m down to bare wood. On the kitchen addition done 20+ years ago, there are only some small areas of paint peeling, which have been removed to bare wood. I planned on priming everything, should I just prime the bare wood areas? If I prime the painted areas as well, would it make for a better finished look?
Kevin
  1. DonCanDo | Sep 23, 2009 12:43am | #1
    Interior or exterior?
    That would determine my choice of primers, but in either case the best job would be to spot prime any bare wood and once that's relatively dry, prime everything.  I'll often skip primer where the paint is in good condition, but I've never regretted using it.
    Just be aware that unless you tint the primer to the final color, using a primer is unlikely to reduce the number of top coats needed.
    1. dockelly | Sep 23, 2009 01:10am | #3
      Hey Don
      It's the exterior, I'll attach a picture.  Took that pic awile back, much more paint has been removed since.  I'll prime everything, primer is whites and so is paint, 2 coats SW, some pink on fish scales at front and back of house and trim.
      Kevin
      1. Shep | Sep 23, 2009 03:13am | #8
        PINK??!!
        Come on, man. Don't let your wife pick the colors.
        <G>
        1. dockelly | Sep 23, 2009 03:50am | #10
          She was pushing for the whole house being pink!
          1. Shep | Sep 23, 2009 04:25am | #12
            compromise is good for for a healthy sex life <G>
      2. DonCanDo | Sep 23, 2009 04:40am | #13
        Much as I hate working with oil-base primers, they really do adhere better than latex primers.
        As long as the areas aren't too big, I like to apply the first coat of primer with a brush.  I feel that it works it into the grain better.  It's not because I've seen any paint failures when rollering primer, it's more of a gut feeling.  Any old latex brush works fine.  I prefer stiffer brushes such as the GenX brushes by E&J.  In between uses, I put them in a plastic bag and store them in the freezer.  When I'm done with the brush, I throw it away.
        Be sure to post a pic with the pink fish scales.  It will probably look better than it sounds :-)
        1. dockelly | Oct 06, 2009 02:14am | #14
          I planned on brushing the whole house. I'll definitely be posting pics, only a few more days of prep, hopefully be painting by the end of the month.
        dedhed6b | Oct 06, 2009 04:15am | #15
        That gable end is crying for some outrageous colors."Shawdow boxing the appoclipse and wandering the land"
        Wier/Barlow
  2. migraine | Sep 23, 2009 01:10am | #2
    Prime it all IMHO
    I can usually see a difference and my vision has gotten worse in the last 10 years.
    My personal pet peeve is when the "interior desecrator" puts 12'x12" color samples on virgin walls.
    Sphere | Sep 23, 2009 02:12am | #4
    Both.
    Hit the bare spots , then prime the whole. It helps build the bare back to the finished level for a more even top coat.
  4. Piffin | Sep 23, 2009 02:17am | #5
    I'm like Duane - spot bare wood, then total prime.
    1. dockelly | Sep 23, 2009 03:04am | #6
      Thanks guys!
        Sphere | Sep 23, 2009 03:12am | #7
        Hey Doc, I did buy one of them Wagner Paint Eaters, a big scrubby pad that strips paint.
        It does work well for feathering and blending but not so hot for total stripping. Like 80 bucks at Lowes. 16 for a new pad.
        I saw yer thread on sandblasting , and didn't get to it, but in a nutshell, don't.  Heat gun and sharp shave hooks is the ticket.  Follow with something like that paint eater and yer golden.
        Now about my T3-T4, can I put a grease nipple there?Spheramid Enterprises Architectural Woodworks
        1. dockelly | Sep 23, 2009 03:49am | #9
          Duane,Why would you need a grease nipple at T3-4, most of your spine motion is in the cervical (neck) and Lumbar (low back). If it's stuck, see your chiro:)
            Sphere | Sep 23, 2009 04:00am | #11
            Trapezious muscle next to the scapula spasms and yanks that outta whack. Old injury. Scapula, ribs and sternum all took it pretty hard.
            Heh, my chiro gave up. Said there was nothing more he could do.  Meloxicam saved my life I think, 10mg a day vs. 3600 mg of Ibuprofen.
            I can do cool tricks like pop my rib outta my sternum tho' (G)Spheramid Enterprises Architectural Woodworks
Grout-Free Shower Panels
  • A Postwar Comeback
  • Natural Simplicity
  • A Grand Rescue on the Coast
