Primer recommendations?(Exterior Trim)
rwjiudice | Posted in General Discussion on March 20, 2008 06:37am
Any recommendations for the “best” primer for exterior trim on a house?
My last paint job is peeling down to bare wood (pine?)
Kilz? Bullseye? Thanks
  1. Riversong | Mar 20, 2008 07:58pm | #1
    You either have a moisture problem or inproper wood prep before painting (too moist?).
    Pine generally requires at least touch priming over knots with BIN alcohol-based primer (shellac).  Then any good quality water-based primer is acceptable.
    But I'd look first for moisture intrusion - either from poor flashing/caulking details or from indoor humidity diffusion.
    Riversong HouseWright
    Design *  * Build *  * Renovate *  * Consult
    Solar & Super-Insulated Healthy Homes
    Edited 3/20/2008 12:59 pm ET by Riversong
  2. DonCanDo | Mar 20, 2008 08:20pm | #2
    Kilz and Bullseye are brands, not a specific primer.  They both make good products.  The "best" primer for exterior use is usually an oil-based primer like Zinsser Cover Stain, but if there's moisture behind it, oil will peel just as soon as latex.  Actually, it may even peel sooner because oil-based paint/primers are more impermeable to moisture so more of it might build up behind it.
    1. rasher | Mar 21, 2008 12:08am | #3
      I use only Benjamin Moore oil-based exterior primer (Benjamin Moore Fresh Start Moorwhite¯ Penetrating Alkyd Primer) and haven't had any problems whatsoever.
Picture-Perfect Pergola
