I’m building a privacy fence and the post will be right next to house. I don’t really want to bury the wood due to termites. I could use a galv post or concrete footer and bolt it. what do you suggest? Doug |
![](https://images.finehomebuilding.com/app/uploads/2024/04/29113159/BUILDING-SCIENCE-SYMPOSIUM-1-Large-thumb-16x9.jpeg)
Check out the lineup for the 2024 Building Science Symposium featuring experts like Steve Baczek, Dr. Joe Lstiburek, and more.
Use some sort of metal pin at the bottom, fasten it to the house near the top.
Pretty much what DanH said.
Concrete footer with a bolt at the bottom, then fasten to house near the top.
Jim
I wouldn't bother with the concete unless I had to. Just drive a pipe at the bottom, fasten it to the side of the post, or drill the post to fit over it. Use some sort of spacer to hold the post up off the ground.
I'm doing something similar, and I'm going to mount joist hangers on the house to hold the rails. No post needed.
It may depend on your exterior siding. Not everything can be easily attached.
We've got fiber cement shingles on our house. I was concerned about attaching directly to the siding, so poured a footing next to the foundation and set a post anchor. Used the wood post as the main support for the fence, but ran the top rail over to the siding for some additional support/stiffening. Has worked well so far.
It's best if you can anchor to a stud behind the siding, but since the purpose of the attachment is generally to prevent motion in the plane of the siding, any sort of reasonable attachment should work.One approach I like is to attach a pseudo-post or weather-proof 2x to the house, top and bottom, using some sort of standoff to achieve about an inch of spacing. The fence rails can then be attached to that. The bottom of the post can be lagged to the sill, and, for FC, the top can be attached via a toggle bolt, if no stud is behind. If using a toggle, have the top anchorage fall just under the lap, to hit the stiffest area and also take advantage of the lap to direct water away.
