Problems with Cabot stains??
smiley | Posted in General Discussion on July 9, 2006 09:53am
I built a large pressure treated deck (spf) and let it sit for 2 years before finishing it. I finished it in Sept-Oct and by Jan-Feb the finish was peeling in great big flakes.
Just wondering if anyone else has had issues with Cabots semi transparent, tinted deck/fence stain?
  1. jc21 | Jul 09, 2006 10:16pm | #1
    I've had good luck with Cabot's products over the years. You might try calling their technical service department- 1 800 US STAIN. What kind of prep work did you do?
  2. wrudiger | Jul 09, 2006 10:41pm | #2
    How did you prep your deck?  After 2 yrs I can imagine any kind of finish peeling unless the prep was immaculate.
    Not the same stuff, but... I used Cabot's Australian Timber Oil on a hardwood deck and it was gone in <4 months.  Several others here and on the decks forum have mentioned the same problem.  I've noticed lots of complaints about most or all of the low-VOC products - from just about every manufacturer; even if their "normal" finish is the best thing ever.
  3. Piffin | Jul 10, 2006 02:03am | #3
    spf and not SYP?
    Anyway, after two years, that wood have a lot of dirt ground into it. If you did not prep by sanding, vacumnig, and using a tack clothe, you should expect it to come back off agin
  4. experienced | Jul 10, 2006 02:27am | #4
    Most likely not a stain problem but preparation problem. You've got to paint/stain fresh dry wood before the sun/elements start ot modify the surface! I have 19 year old Cabot stain on my wood shutters and its just starting to need re-staining if you view it up close....from the road looks very good. The wood window sills that get a lot of direct perpendicular sunlight needed stain at 14-15 years. Have not seen many stains last that long.
  5. paperhanger | Jul 10, 2006 03:19am | #5
    Finished in Sept-Oct. in Alaska. What where the weather conditions and was there a moisture problem from a morning dew. That was pretty late in the year around here, never mind Alaska. Sounds to me like poor adhesion due to a moisure problem.
