Problems with Paslode Finish Nailer
chriswinder | Posted in Tools for Home Building on June 18, 2008 03:41am
 Has anyone else experienced problems with this finish gun? I just purchased it a few months ago and at first it worked great. A few weeks ago I started having problems. I made sure that my cartridges were not expired and that the battery is fully charged…but still no go!. It just won’t fire nails when I go to shoot something. Any advice would be appreciated.
    Sphere | Jun 18, 2008 03:51am | #1
    Check that the gas cylinder is truly engaged with the port? Check that the gas cylinder is indeed with gas?
    I have had mine for quite awhile and those two are the only reasons it wont fire..if the fan runs, the batt is OK.  The only other thing (readily common) is are you pressing it hard enough to overcome the safty spring.
    "We strive for conversion,we get lost in conversation, and wallow in consternation. "
    Me.
  2. MSA1 | Jun 18, 2008 04:04am | #2
    It may have jambed. Make sure the plunger is in the upright position, otherwise it wont fire. You also may have a nail jambed in there. Open the nose and check it out.
  3. 2weekstops | Jun 18, 2008 04:48am | #3
    clean and oil it , thats what we all forget to do ...youd be amazed at what regular maintenance
    Edited 6/17/2008 9:50 pm ET by 2weekstops
  4. Shep | Jun 18, 2008 05:23am | #4
    Sometimes I have problems if the depth adjustment is set too deep. Its worth a check.
  5. RedfordHenry | Jun 18, 2008 05:44am | #5
    What's the indicator light saying?  Every once in a great while, mine will start running poorly.  A thorough cleaning and a fresh fuel cell has always done the trick.
  6. danno7x | Jun 18, 2008 05:46am | #6
    I have forgot to push the cap down on the new gas cartrage when I put it in and took a little while to figure it out because if you just glace at it it may look all the way down but its not really,  made me feel pretty silly.
  7. cooptrac | Jun 20, 2011 09:47pm | #7
    paslode finish nailer
    I have a Paslode finish nailer.   The battery is fully charged.  However when I put the batter into the
    battery compartment it clicks in but I get no power and no indicator light
    Any ideas ?
  8. dastick | Dec 19, 2011 11:10pm | #8
    paslode finish nailer angled
    try gently pushing on battery and then lightly depress trigger till it cycles , then gun will fire at least once.Still trying to figure the rest of the problem out. but I'm thinking the vibration of the shot loosens the contact of the battery. Islightly pull on trigger to cycle it and then it will fire.This does not help when holding material, on ladder 3 stories up with 20 knot winds but it may lead you to a solution of where problem may be stemming from.The gun does not need to be depressed to cycle after the gentle pull on trigger.
